EBPV Plug
Old Jan 17, 2009 | 03:47 PM
mblanken881's Avatar
mblanken881
EBPV Plug
What does the plug look like for the EBPV? I would like to unplug and just be down with the thing. THanks, Mike
Old Jan 17, 2009 | 03:59 PM
ron's power stroke's Avatar
ron's power stroke
you can un hook the plug at the pedistal under the turbo by pulling up on the wire locking clip and then pull the plug out...doing this will default the EBPV to open and it will stay there..you will get a soft code doing this but no light....there is a resistor if the code bothers you... <!-- / message --><!-- sig -->
Old Jan 17, 2009 | 04:02 PM
ron's power stroke
the plug will be just above the blue dot in this pic
Old Jan 17, 2009 | 04:22 PM
mblanken881
is it a white plug or a black plug?
Old Jan 17, 2009 | 04:47 PM
Izzy351's Avatar
Izzy351
It's black plug wrapped in the black loom stuff. You can't miss it. But it's plugged into that white plug just above the blue dot in Ron's pic.
EDIT: You can see mine plugged in in this pic (Click the thumb, then click the little magnifying glass under the pic to see it full-sized):
Capt.Schenk
13
Jan 22, 2015 12:14 PM
Deluxe06
Jan 20, 2011 07:25 PM
60RatRod
16
Jun 16, 2010 01:32 PM
JethroF250
Mar 26, 2008 10:12 PM
injun46
Nov 29, 2005 04:14 PM
