low blower speed doesn't work
Old Jan 16, 2009 | 01:22 PM
tompro1's Avatar
tompro1
I have a 2006 F150 and my blower doesn't work on the #1 setting. Usually if the resistor goes out doesn't it blow at high speed? i have speeds 2-4. i tried a new switch but it still doesn't work. Is my next step a new resistor or am i missing something?
Old Jan 16, 2009 | 02:34 PM
72bronc's Avatar
72bronc
Usually if the resistor is blown the blower will only work on high speed.
(no resistance). depending on how the resistor is set up it is possible that only the low speed does not function.
Old Jan 16, 2009 | 02:38 PM
tompro1's Avatar
tompro1
i just pulled out the resistor and it looks like a big microchip. the only speed that worked with it unplugged was high. i know that the #1 setting blew air before. is there a way to check that kind of resistor?
Old Jan 16, 2009 | 02:55 PM
72bronc's Avatar
72bronc
manual or electronic climate control?
Old Jan 16, 2009 | 03:02 PM
tompro1's Avatar
tompro1
it's manual.
Old Jan 16, 2009 | 03:16 PM
72bronc's Avatar
72bronc
yes check the resistance of the resistor lol
4 pins correct?
top
1 2 3 4
top being that is where the clip is the bottom is flat
resistance of 4 & 2 2.0-2.6 ohms
" - " 2 & 3 .2-.4
" - " 2 & 1 .8-1.1 ohms
if they are not in spec the risistor is bad.
if they are you have a blower switch or wiring issue
Old Jan 16, 2009 | 03:20 PM
tompro1's Avatar
tompro1
man i appreciate your help. the plug is 4 pins, flat. i'm gonna assume the one onthe left is #1. correct?
Old Jan 16, 2009 | 03:23 PM
72bronc's Avatar
72bronc
yes if u consider that the top is where the clip is
the bottom is flat yes left to right 1234
Old Jan 16, 2009 | 05:18 PM
tompro1's Avatar
tompro1
72 Bronc you were absolutely correct. i checked the old resistor, went and bought a new one, it's now installed and working great. thank you for all your help. this was tremendous help. 72 Bronc you are the greatest!!! thanks again.
Old Jan 16, 2009 | 07:48 PM
72bronc's Avatar
72bronc
No problem
Mustangking1
Jan 24, 2017 09:15 PM
danielcoyle
May 31, 2014 06:46 AM
O-Dog
Jan 23, 2012 10:22 PM
5jordan
Aug 5, 2004 10:29 PM
