A/C blower motor not running on high
Ok,I got my a/c hooked up...when I flip the switch up to high the blower doesn't blow air, this is how it works,
Low- yes
Both Medium - yes
High- NO, it blows low
the resistor has four wires going to it, the black wire is solo, and the other three are together.
Bad resistor?
Thanx
Low- yes
Both Medium - yes
Bad resistor?
Thanx
I have a similar but different problem. When I have mine on high there are times when I hear a ping or click and the fan blows a little harder then another click and the fan goes back to a lower setting. How hard is it to replace the switch? I do have another HVAC control that I can take the switch out of.
on
To test the switch, set it on high with the ignition switch in run, check the orange/black wire coming out the back of the switch. It should be hot.
The blower motor resistor changes resistance on the blower motor's ground wire to adjust speed.
There is a splice in the orange/black wire where it wyes off and one section goes between the blower motor resistor and blower motor, and the other section goes to the Blower switch. When the switch is on low, or one of the mediums (2), the blower motors ground goes through the resistor. When on high, the switch connects the blower motor's ground direct to ground.
Check the Orange/Black wire between the splice and the blower motor switch for a break.
on
Ok, turn the fan speed switch to one of the medium settings.
If the switch is bad, and not the wiring, you should have power on the Orange/Black wire at the switch as it back feeds from the wye from the resistor toward the switch.
If the Orange/Black wiring is bad between the switch and the splice where it wyes off, it will still be dead.
This is assuming your blower works for medium.
I really appreciate your help..Thanx
on
The Blower switch basically changes the pathway to ground. Either directly to the switch when switched on high, or through the resistor for the medium and low settings.
Since no power is getting to the blower switch at all in either mode on that Orange/Black wire, this is the problem wire.
For it to work on medium and not on high in this state, it has to be the wiring between the wye splice where it connects to the blower motor/resistor pathway and the switch.
The orange/black wire has to be functional between the motor, the wye splice and the resistor for medium and low to work, unless your guy who wired it, bypassed it somehow. If you see where I'm at with it.
I just replaced my blower motor last week. The speed selections were working, but barely. My plug connection at the motor had crumbled. When I wired it back together, I could here the motor run, but had no air volume.
I put the new motor in and could hear it run its butt off and still had no volume. I wound up connecting my black motor wire to the trucks orange and the motors orange wire to the trucks black. The truck air has never worked as well as it is now.
I do not know if this could help. Mine was just doing very weird things similar to you. The motor was around 22 bucks from o reilly.
Also to mention my trucks wiring is all intact. No cut and splices on it.
The Orange/Black wire is the main ground wire from the blower motor.
Your welcome.
Your welcome.
johnem
02-09-2007 10:56 AM
aaronstottle
07-07-2006 01:54 PM
99lightning
08-12-2002 03:52 PM
