tranny filter question
Old Jan 15, 2009 | 10:06 PM
bigbubba87's Avatar
bigbubba87
OK i just bought my 2000 f350 and it has a frame mounted tranny filter. is it supposed to have one like this?
Old Jan 15, 2009 | 10:20 PM
jdecker88's Avatar
jdecker88
Nope thats an extrnal aftermarket tranny filter. The actual filter is up in the transmission just under the tranny pan.
Old Jan 15, 2009 | 10:21 PM
Izzy351's Avatar
Izzy351
That's after market. Some are of the opinion that they slow flow. Personally, I don't think they're needed. Just my (not so) humble opinion....
Old Jan 15, 2009 | 10:22 PM
jdecker88's Avatar
jdecker88
Its not like you change your tranny fluid that often any ways so there is really no need in it.
Old Jan 15, 2009 | 11:50 PM
SpringerPop's Avatar
SpringerPop
It tells me that the previous owner cared enough about his truck to add it.
We can't keep the fluids TOO clean, now, can we?
Since we don't change the fluid that often, it's all the more reason to filter it better.
The in-pan "filter" is not much more than a strainer, anyway.
I'd change the spin-on each time you change the tranny fluid.
Pop
Old Jan 16, 2009 | 06:24 AM
bigbubba87's Avatar
bigbubba87
ok thanks i figured it was aftermarket. no i just got to find a filter.
Old Jan 16, 2009 | 06:41 AM
Izzy351's Avatar
Izzy351
Of course you can't keep it "too" clean. But you can cross into diminishing returns, and possibly overheat the tranny if that thing clogs for some reason. Dino fluid when it's cold gets thick enough to slow or even stop through the standard coolers, so I imagine it slowing even more (or sooner) with a filter inline. If the stock filter was that bad, we'd see more filter related issues, I would think. Keep in mind that Brian from BTS doesn't believe in auxiliary filtering either.
My advice to the OP is do what you are comfortable with. I'd take it out if it were me.
Old Jan 16, 2009 | 08:33 AM
Ponyboychris's Avatar
Ponyboychris
On my old PSD, when the tranny blew, the dealer installed an in-line tranny filter as part of their reman tranny TSB. Just a thought.
Old Jan 16, 2009 | 08:43 AM
Izzy351's Avatar
Izzy351
Do you have an in-line with your BTS, Chris?
Old Jan 16, 2009 | 08:51 AM
Ponyboychris
Nope. Like mentioned above, Brian said no need for it.
Old Jan 16, 2009 | 09:10 AM
mueckster's Avatar
mueckster
The filter that goes in the cooler line, near the radiator, is a magnetic filter. I don't think it really "screens" out any extremely small particles. I haven't seen the internals of one of these yet. I did install one on my stepson's old F150, after the TC shelled out, for "good measure".
Old Jan 16, 2009 | 09:12 AM
Ponyboychris
Yes, that was exactly what it was. A Magnafine filter.
Old Jan 16, 2009 | 09:22 AM
big poppa's Avatar
big poppa
There,s a filter in that line i got to worry about, or do i ???? First time i heard of a filter there.
Old Jan 16, 2009 | 09:28 AM
Ponyboychris
Well, when Ford put that on my old truck (not my current truck in sig), it was spliced in-line to the cooler line before it entered the tranny cooler on the passenger side under the radiator. If you have one, it should be visible. Like I mentioned before, it was placed there after the dealer installed a reman tranny and it was part of the TSB. I recall having a sticker also placed on the radiator shroud to call attention to it. Was supposed to be changed at every tranny fluid change. It pretty easy to spot.
It looked like this:
Magnafine Dual Inline Transmission Filters : JC Whitney: Auto Parts & Accessories
Old Jan 16, 2009 | 09:40 AM
mueckster's Avatar
mueckster
This is taken from my Ford dvd manual:
If the transmission was overhauled and the vehicle was equipped with an in-line fluid filter, install a new in-line fluid filter.
If the transmission was overhauled and the vehicle was not equipped with an in-line fluid filter, install a new in-line fluid filter kit.
If the transmission is being installed for a non-internal repair, do not install an in-line filter or filter kit.
If installing a Ford-authorized remanufactured transmission, install the in-line transmission fluid filter that is supplied.
It not recommended to install one, if you have no transmission problems.
