help plz
Old Jan 15, 2009 | 02:54 PM
badblueoval4life's Avatar
badblueoval4life
i will say this its the first time in the five and a half yrs ive owned it that it wont start 5and a half yrs and 156,000 miles???
Old Jan 15, 2009 | 03:13 PM
badblueoval4life
could the gpr keep it from starting??????? if its bad that is???
Old Jan 15, 2009 | 03:18 PM
badblueoval4life
if so how do u check it???????????
Old Jan 15, 2009 | 03:40 PM
badblueoval4life
anybody ???????????????
Old Jan 15, 2009 | 04:04 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
You know where the GPR is, yes? BE CAREFUL, but you can jump the 2 big terminals for about 20sec with a big screwdriver (or jumper cables).
To test the GPR, KOEO (Key On Engine Off) and use a voltmeter to see if you are getting 12v + to the GPR's big terminal that is closer to the fuel bowl (center of engine). If you don't get any voltage, the GPR is toast.
If the GPR is toast, plug her in and read this:
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Go straight to Stancor, do not pass GO, do not collect $200....
If you have an engine block heater, and after being plugged in for 2hrs+ she fires up, that also points to your GPR being history.
Old Jan 15, 2009 | 05:25 PM
badblueoval4life
i dono whos idea worked but its back up and running again so thanks to all whom replied or had any suggestions.
shawn
Old Jan 15, 2009 | 05:47 PM
Ponyboychris's Avatar
Ponyboychris
shawn
OK, what fixed it???
Old Jan 15, 2009 | 06:08 PM
Tecman's Avatar
Tecman
I bet it was gelled fuel.
It tooks a massive torpedo heater blasting under my truck for a few hours with cardboard around the sides to keep the heat in before it would finally start. And by the sounds of it, the way you describe the starting, it sounds jsut like mine when it gelled.
Glad you got it back up though!
Old Jan 15, 2009 | 08:01 PM
badblueoval4life
i put the battery charger on it for an hour or so cycled the key 3 or4 times and it started and ran like a new one?? i put 2 bottles of super dry in it and drove it bout 5 miles!! we will see in the mornin i guess??? thankfuly they called of my work so i dont have to leave at 5am when its 0 outside??? thanks to all that helped me out.
shawn
Old Jan 15, 2009 | 08:31 PM
big poppa's Avatar
big poppa
I would say it was your batteries, check them seperately for voltage output. Might as well check the glow plug relay while your there also.
Old Jan 15, 2009 | 09:45 PM
BDalton's Avatar
BDalton
If your batts are four years old like you mentioned, you might be approaching the end of their useful life span. Some get more, some less, but four year old batts, plus the weather you guys have been getting may be the combo that has caused you this pain. .02
Old Jan 15, 2009 | 10:07 PM
Ponyboychris
Batteries would be my guess as well. The cold weather will knock marginal ones down to the point of needing to be replaced.
Michael Chinn
Oct 21, 2014 05:30 AM
Justinbel4
Aug 20, 2010 01:25 PM
kmbradley87
Nov 15, 2006 11:27 PM
mdg97222
15
May 5, 2005 05:31 AM
