Warm up valve...
Old Jan 15, 2009 | 10:05 AM
mxracer3276's Avatar
mxracer3276
Warm up valve...
When it gets cold like this, when the fast idle kicks in, it sounds like my exhaust is forcing out a lot of air. I was told this is called a warm up valve. Is there a more technical name for it? Is it alright to drive while this valve is open or wait till the truck warms up and that shuts off?
Old Jan 15, 2009 | 10:08 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
It's the EBPV (Exhaust Back Pressure Valve) and its function is to help warm-up. Sounds like a jet engine a bit, right? It's working properly then. Search EBPV or EBP on this forum and you'll find lots more info if you want it.
Old Jan 15, 2009 | 10:11 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
When you get in the truck and step on the brake, it should turn off. Meaning the valve should open, and the idle go down.
Old Jan 15, 2009 | 10:13 AM
superduty4x4's Avatar
superduty4x4
Touching any pedal is supposed to deactivate it. The real fun comes when it starts shutting while you drive down the road, making all kinds of nice racket and causing your truck to act all weird. I vote to unplug the dang thing. Wire it onto a switch if you want to be able to close it for warm-ups, but it really doesn't help much.
Old Jan 15, 2009 | 10:24 AM
mxracer3276
Yeah definitely like a jet engine. A little bit annoying.
When i step on the brake, the high idle shuts off but when i go to drive it still sounds like a jet engine. Loud as could be.
Yeah you're exactly right, the trucks acts real weird. Almost like it doesn't want to go. When i hit the pedal, it's like it opens and runs fine but when i let off the pedal or lighten up on itm it closes and gets loud again.
Old Jan 15, 2009 | 10:31 AM
superduty4x4
When the valve closes it almost closes the exhaust off completely, that's why you have very little power. Unplug it!
Right above the blue dot in the pic you can see the solenoid for the EBPV (unplugged in pic)- flip the wire lock tab up and pull the connector out and no more annoying EBPV.
Old Jan 15, 2009 | 10:41 AM
mxracer3276
Thanks Chase, i think i will wire up a switch for it. Definite reps for the help.
Old Jan 15, 2009 | 10:47 AM
mxracer3276
If i wire up a switch, will i need an inline fuse for or should i just run it through the fuse panel to one of the auxillary fuses?
Old Jan 15, 2009 | 11:36 AM
superduty4x4
I would throw a fuse inline, easy sleazy.
Old Jan 15, 2009 | 11:40 AM
mxracer3276
That's what i figured. Thanks for the help Chase!
Old Jan 15, 2009 | 11:42 AM
superduty4x4
Not a problem, glad I could help.
Old Jan 15, 2009 | 12:54 PM
redfire42's Avatar
redfire42
When I wired my EBPV/ brake in I also wired it so the ECU controls it or I control it. It turns on and off normaly but I can also turn it off completly if I want witch making it nice so the stuped thing doesn't turn on when driving.
Old Jan 15, 2009 | 01:01 PM
mxracer3276
Could you give a quick hint on the steps you took in doing that?
Old Jan 15, 2009 | 02:42 PM
ITA47's Avatar
ITA47
I second that request! I would like to hook mine up like this also, please advise how you wired it.
Old Jan 16, 2009 | 10:04 AM
redfire42's Avatar
redfire42
https://www.ford-trucks.com/user_gal...134199&width=0
not sure how to post the picture from someone elses gallery.
I did what Dan did but I also added another switch on the switched power line. That lets me turn off the use of the EBPV/Brake. It just kills power to the switch letting you turn on or off the ECU's use of the EBPV. When the idle kicks up the EBPV will not close inless you hit the switch. Hiting the switch again will turn it off not sending the signal from the ECU to reach the EBPV. The only thing, when wiring the switch in to the hot wire not letting the power to the switch, you must switch your in dash swich to the on witch in end blocks the signal from the ECU to the EBPV. I hid the hot power switch under the fuse panel. Its a pain in the but, but I don't tow in the winter to need the EBPV/Brake so I just turn it off completly and use the switch to have control over the ECU's use of the EBPV.
I am no good at explaning things so I hope this helps alittle.
Last edited by redfire42; Jan 16, 2009 at 10:05 AM. Reason: Sorry its PCM not ECU LOL
parkland
6.4L Power Stroke Diesel
Dec 9, 2014 09:55 AM
abe
Oct 12, 2012 12:05 PM
ford141
Oct 27, 2011 08:51 PM
terriblet63
Dec 15, 2009 04:51 PM
stroker"1"
Feb 25, 2005 06:33 AM
