heat riser
Old Oct 11, 2012 | 08:28 PM
abe's Avatar
abe
heat riser
Question about the heat riser on my 1970 F350 with a 360. It should be closed when the engine is cold so it gets warm air and then it should open up after the engine is warm, right?
Looking at it today after I ran the truck and the engine was warm, the flapper was up meaning it is not getting air from the outside but from the engine.
How does this work. (is it a bi-metal valve?) How do I correct it?
Old Oct 12, 2012 | 05:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It should be closed when the engine is cold so the engine warms up faster. Then it should open up after the engine is warm, right?
Correct, except there's no such thing as original, your trucks left exhaust manifold has been changed.
C5TZ-9431-A .. Left Exhaust Manifold-Use with Heat Riser Valve: 1965/67 F100/350 352 & 1973 F100 360.
D3TZ-9A427-A (replaced C5TZ-9A427-D) .. Heat Riser Valve: 1965/67 F100/350 352 & 1973 F100 360.
C8TZ-9431-B .. Left Exhaust Manifold-Use without Heat Riser Valve / 1968/76 F100/350 360/390 except 1973 F100 360.
The flapper is notorious for rusting solid in the open position. People removed the flapper, welded the holes.
Old Oct 12, 2012 | 08:40 AM
abe's Avatar
abe
Thanks, Bill but I think we are talking about 2 different things. The heat riser, or flapper, I am talking about is in the breather neck of the air filter. Yes on the older trucks like my '54 the riser is on the right manifold.
Are the springs shot does it need some WD40 to loosen it up????
Old Oct 12, 2012 | 12:05 PM
orich's Avatar
orich
That is the Hot air pick up off the exh manifold. those do go bad. Maybe the little spring is broken or a good cleaning and a shot of wd40 get it working again ..orich
Amphihauler
Jan 31, 2017 03:06 PM
born4ford
Apr 23, 2016 11:22 AM
brbuchanan
May 26, 2015 10:36 PM
Ripperg9
Aug 24, 2013 09:03 AM
1968Lew
May 16, 2011 06:36 PM
