Shudder turning left
Old Jan 15, 2009 | 06:36 AM
CanadianSmokie's Avatar
CanadianSmokie
I have read the other posts on here on shuddering upon acceleration, however, mine only does it when making a left hand turn. I know I still need some front end work done (left ball joints, possibly tie rods and sway bar bushings) would these front end issues be causing the shudder? It seems to be more coming from the rear though..... btw, rearend fluid was changed out less than a year ago with Royal Purple.
Any ideas would be helpful...thanx
Old Jan 15, 2009 | 07:02 AM
landcruzr's Avatar
landcruzr
Can you go up another block and then turn right, double back around, and come in from the other side so you only have to make right turns?
Sorry 'bout that....I'm obviously tired
Old Jan 15, 2009 | 08:11 AM
whjco's Avatar
whjco
Ken,
Does your Ex have 4wd and is it engaged when it's doing this? If you have 4wd, it might not be releasing on the left front, you may have a u-joint that's going bad, or possible wheel bearing problems. It might be worth jacking up that wheel and inspecting everything.
Old Jan 15, 2009 | 08:27 AM
CanadianSmokie
LOL!!
That's what I love about this forum... insightful, well thought answers
Thanx Whjco, I'll have my wheel bearings checked out... I know it's not 4X4 problem.
BTW, has anyone ever had their rear bearings replaced or are these typically never a problem?
Aug 30, 2014 01:50 AM
Mrjenkins262
Apr 14, 2010 12:34 AM
Zip
Dec 29, 2008 02:26 PM
flajoker
Jul 11, 2006 08:37 PM
BuddyB
Jun 9, 2003 10:49 PM
