Max Gear
Old Jul 11, 2006 | 06:29 PM
flajoker's Avatar
flajoker
Max Gear
Can I run Royal Purple Max Gear in the front and rear end of my f250 6.0 4x4?
Anyone using Royal Purple oil?
Old Jul 11, 2006 | 08:37 PM
tvsjr's Avatar
tvsjr
Does it hold all of the certifications as listed in your owners manual? And that means *certified*, not just meets certification standards like some products (you know, starts with an A and ends with an "msoil").
Does the weight match?
If so, then yes. If you've got a limited-slip rear, you might want to contact RP regarding what to do in terms of friction modifier, otherwise you'll either lose your limited slip or burn the clutches up.
weluv
6.2L V8
Oct 5, 2014 10:14 AM
WABowHunter
6.7L Power Stroke Diesel
52
Mar 27, 2014 03:06 PM
FixOnRoadDaily
Oil & Lubrication
16
Nov 10, 2005 05:00 PM
kelro
Oil & Lubrication
May 28, 2005 11:50 AM
Black92 5.0
2004 - 2008 F150
May 19, 2005 04:23 PM
