LED lights
Old 01-14-2009, 07:43 PM
AspenF150's Avatar
AspenF150
AspenF150 is offline
LED lights
I'd like to get some LED lights for the rear tailights and 3rd brake light on my truck.
I know there's a bunch of different brands out there, which brand do you all feel is good?
Edit: I've read somewhere that after one puts LED lights on there F150's, the radio stops working or the turn signals don't work right?
Old 01-15-2009, 07:09 AM
ReAX's Avatar
ReAX
ReAX is offline
LEDs have a very low current (amperage) draw. The bi metal turn signal flashers require a certain amperage draw to heat the switch up. Once the switch reaches a certain temperature, the switch opens up and disconnects power from the light. LEDs don't heat the flasher enough to trip it. Newer vehicles are getting electronic flashers, so this is becoming less of an issue. However, if you have a metal flasher, you will need to change to an electronic.
I don't think the tail light circuits will have any bearing on the radio, unless the 05+ CAN is more integrated than I give it credit for.
Old 01-15-2009, 10:18 AM
Steina's Avatar
Steina
Steina is offline
CO River Rat
Before you buy, ask if the units have built-in resistors (the ones I bought from XtraLights do).
Steve
Old 01-17-2009, 07:04 AM
boxcar1974's Avatar
boxcar1974
boxcar1974 is offline
Here is a old thread with a lot of good information, pics, and videos or LED lights.
I bought new tail lights instead of just the bulbs. They were not that expensive and I like to look of the new lenses. I bought red/smoke lenses.
take a look
https://www.ford-trucks.com/forums/5...il-lights.html
Old 02-14-2009, 09:46 PM
john_from_ict's Avatar
john_from_ict
john_from_ict is offline
I fabbed some separate LEDs into the OEM taillights that I like the look and just replaced the bulbs in my third brake light w/LEDs from superbrightleds.com
Old 03-12-2009, 09:21 PM
chromy's Avatar
chromy
chromy is offline
Steve
you dont need the resistors, you need to buy the heavy duty flasher unit
Old 03-12-2009, 10:26 PM
Steina's Avatar
Steina
Steina is offline
CO River Rat
Just because it's heavy duty doesn't mean it will work with LEDs - you need either an electronic flasher or resistors to keep the flash rate normal.
Steve
Old 03-13-2009, 11:27 AM
chromy's Avatar
chromy
chromy is offline
Steve
i installed front LED signals and LED tail lights, put an EP-27 Flasher Unit in it and it cured all the flash rate problems
Old 03-13-2009, 12:41 PM
ReAX's Avatar
ReAX
ReAX is offline
The EP-27 is an electronic. The terminology difference is, the old bi-metal flashers came in standard and heavy duty. The heavy duty was pretty much required for any tow vehicle because hooking a trailer increased the load on the circuit and caused the lights to flash too quickly. The HD flashers took longer to warm up and kick out. Electronic flashers use a time based rather than current based sense. You can get fancy ones that allow you to adjust the time off and time on, or the generic like the ones used on heavy trucks.
Old 03-13-2009, 01:06 PM
Steina's Avatar
Steina
Steina is offline
CO River Rat
If you're buying LED light assemblies that have resistors installed (not all do), then the flasher type doesn't matter; that's why it's a good idea to ask before you plunk down your $$$.
Steve
TRENT310
6.7L Power Stroke Diesel
15
02-17-2015 10:41 AM
MxDad567
Appearance & Dress-Up
01-21-2014 03:01 PM
Christopher Roche
2004 - 2008 F150
11-26-2013 05:14 PM
hemikidd
All Other Items for Sale
11-25-2013 10:26 PM
01expyEB
Aftermarket Products
03-09-2004 01:30 AM
Quick Reply: LED lights
