Could always hook up a variable resistor dial, then after the truck is cranked turn it up until your scanning software sees > 167 degrees EOT.
Or just unplug it. The PCM will see a default EOT for cranking of 68 degrees, then a running EOT temp of 212 degrees. However, I'm not sure if it will complete a CCT test with the EOT unhooked or not. Some scan tools work like that. Worth a shot though.
I'm guessing you have cold running issues or a severe miss that you are trying to track down?
I don't think the CCT can be run with the EOT unplugged. Since the PCM doesn't allow the test to be run on a cold engine, I don't think the scanner type makes a difference.
Thanks for the replies guys. I figured it out. Tried with EOT unplugged and though it read 205 of the scanner it wouldn't run it the CCT. put in a 4.7K and that put it a 163 and it let me run the CCT. Working on a early 99 with dead misses. Just didn't want to warm the engine up again cause I was heading toward compression tests and swapping injectors around to verify. Nice cool engines are much better to work on.
