Cold Engine contribution test
Old Jan 14, 2009 | 07:19 AM
tjbeggs's Avatar
tjbeggs
Do anybody know off the top of their head the resistor value needed to trick the EOT to do a contribution test on a bold engine?
Thanks in advance
Old Jan 14, 2009 | 07:53 AM
Action4478's Avatar
Action4478
Thanks in advance
Bill might Know
Old Jan 14, 2009 | 07:01 PM
F350-6's Avatar
F350-6
I believe a 5.4kohm resistor will give you an EOT of 160, which should work for the CCT, but if it's really cold, might make starting a tad difficult.
Old Jan 14, 2009 | 07:10 PM
Pocket's Avatar
Pocket
Could always hook up a variable resistor dial, then after the truck is cranked turn it up until your scanning software sees > 167 degrees EOT.
Or just unplug it. The PCM will see a default EOT for cranking of 68 degrees, then a running EOT temp of 212 degrees. However, I'm not sure if it will complete a CCT test with the EOT unhooked or not. Some scan tools work like that. Worth a shot though.
I'm guessing you have cold running issues or a severe miss that you are trying to track down?
Old Jan 14, 2009 | 07:26 PM
F350-6's Avatar
F350-6
I don't think the CCT can be run with the EOT unplugged. Since the PCM doesn't allow the test to be run on a cold engine, I don't think the scanner type makes a difference.
Old Jan 15, 2009 | 11:12 AM
tjbeggs's Avatar
tjbeggs
Thanks for the replies guys. I figured it out. Tried with EOT unplugged and though it read 205 of the scanner it wouldn't run it the CCT. put in a 4.7K and that put it a 163 and it let me run the CCT. Working on a early 99 with dead misses. Just didn't want to warm the engine up again cause I was heading toward compression tests and swapping injectors around to verify. Nice cool engines are much better to work on.
thanks for the info!
catman52987
Mar 14, 2012 10:01 PM
MobeyDick
Dec 23, 2011 03:01 PM
arkredneck
Arkansas Chapter
Feb 1, 2010 06:06 AM
xgatorx1976
60
Apr 23, 2008 01:11 AM
bkcowboss
23
Feb 15, 2008 05:46 PM
