Exhaust Question??
Old Jan 15, 2009 | 04:34 PM
BRay09's Avatar
BRay09
Question
Originally Posted by bashby
I say drive it with the open pipe if you like the way it sounds. Be sure to reset your trip odometer so we can know how far you get before you get pulled over. I say in town 2 miles, rural maybe the second or third cop you see. I got pulled over in my 88 toyota with header, 2.25" cat, turbo muffler less than 10k miles old and full tailpipe. I'm still pissed 2 yrs later....but I digress
I put the FM44 on today.... very displeased I may say. Paid $94 for the ****in thing and i think its quieter than having my stock exhaust on!
Anyways, will running open 3" pipe hurt anything? (stock2.5 duals to a dual inlet, single 3" outlet from about 5" in front of O2)
Old Jan 15, 2009 | 05:48 PM
blakem_85's Avatar
blakem_85
With running straight pipes, a 3" should be plenty for a stock engine. Can't say as to whether or not you will get the sound you are looking for. On my '96 I've got true duals (with equalizer pipe) straights with 2" pipes back and then 2.25" tail pipes with 4" tips exiting at the rear corners. Its loud as hell but sounds damn good. I know what you guys are talking about by a straight-piped truck sounding like crap (like a mid 80s chevy with the exhaust falling off of it) but with the right combo you can make it sound pretty good. I ran a flowmaster super 40 2.25" dual in/dual out for a while, it sounded ok but wasn't loud enough . Maybe its just the redneck in me but generally speaking I think that trucks usually sound best with duals of some sort and a glasspack style muffler. Flowmasters and the like make them sound like a mustang...
Old Jan 15, 2009 | 06:32 PM
BRay09's Avatar
BRay09
I may just stick a glasspack down there again, just to have something for a lil backpressure. Hopefully its louder than this POS that I wasted 95 bucks on. But i was told that running just one straight 3" pipe would make the truck run bad because there wouldn't be enough backpressure. But IMO the truck sounded best with just the straight on it!! Idk... Ill figure something out. Thanks for the posts
Old Jan 15, 2009 | 09:29 PM
Conanski's Avatar
Conanski
No need to worry man, a motor does not need backpressure and will perform better with a better flowing exhaust system. There is no(zero) danger of doing any damage to the valves on an EFI motor by altering the exhaust system, The computer adjusts realtime for any change in temperature, barometric pressure, and airflow through the engine. Now a carbed motor is totally different, it can't self adjust so you could cause some damage if the carb isn't rejetted.
Old Jan 16, 2009 | 09:22 AM
BRay09's Avatar
BRay09
So its okay then and there is nothing that will happen to the motor from having no backpressure? If thats the case than that muffler's coming off tonight and going on Craighslist!!!
Old Jan 16, 2009 | 12:56 PM
blakem_85's Avatar
blakem_85
On another note, I'm getting about 3 mpg more with straights than I was with the Flowmaster.
Old Jan 17, 2009 | 02:35 PM
BRay09's Avatar
BRay09
Thanks for the reply's guys. Im going to cut the FM44 out and just run the 3" pipe all they way back!
Old Jan 18, 2009 | 12:16 AM
Beamed's Avatar
Beamed
what u need is a good set of long tube headers and the 44 with a full 3inch thats what im running and it sounds killer ill get a vid with sound tommorrow and about the striaght pipe i watched a vid about exhusts belive it or not u build more hp with a full exhuast running the stock cat and a muffler then with nothing at all ill try to find the vid so u guys can check it out
Old Jan 18, 2009 | 08:59 AM
Jeff Dodson's Avatar
Jeff Dodson
Well I took the Cat off of mine and the Truck sounds like a DANG Mustang. I cant stand that sound. The FLOWMASTER is coming off and the MAGNAFLOW on.
Old Jan 18, 2009 | 10:29 AM
BRay09's Avatar
BRay09
long tubes are coming this summer, as well as a cam upgrade. Any suggestions on what long tubes to use?
Old Jan 18, 2009 | 03:13 PM
Beamed's Avatar
Beamed
some Doug Thorley Headers thats what im running there great but theyll run u around 500 bucks or try the bassini i bought the dual exhust headers and made a custom y pipe
Midnite1987
Mar 26, 2014 08:23 PM
Chris Henley
20
Jan 2, 2013 08:04 PM
99F250Iowa
Modular V8 (4.6L, 5.4L)
Dec 31, 2009 08:37 PM
Krisx125
Dec 8, 2009 10:42 PM
knight60626
Nov 11, 2004 09:26 PM
