General Automotive Discussion
Chevy truck question
Old Jan 13, 2009 | 12:05 PM
93F250's Avatar
93F250
A co worker has a Chevy truck. It's a 1/2 ton and I think it's a 2000 or 2001. Yesterday, he lost his brakes and reverse at the same time. He said he was in reverse (not sure if he was moving or not) when he took it out of 4wd and heard a thump. The tranny fluid smells burnt. Not sure when the last time he changed tranny fluid and filter. Truck has 225k on it. I'm guessing the tranny's gone but that doesn't explain the brakes. Anyone have any experience with the same type of thing?
Old Jan 13, 2009 | 07:02 PM
Flexfuel-Dave's Avatar
Flexfuel-Dave
Was the transmission fluid too low?
Is it time for brake pads or does the pedal just go to the floor?
About the only way the two systems might be related is engine vacuum.
Old Jan 14, 2009 | 01:28 AM
Ship Boy's Avatar
Ship Boy
Temporarily Deactivated
Best to have it towed to nearest dealer.
Old Jan 14, 2009 | 02:47 AM
Sparky83's Avatar
Sparky83
my dads trucks an 03 silverado 1500.. and couple yrs after he got it the parking cable snapped... said when he was talking to the service writer theyd had quite a few of them suddenly snap..
i dunno if its the parking brake your referring to not be working or the regular hydraulic brakes... but could understand if the parking cable snapped at the right spot it could take out the wires in the neutral safety switch..
Old Jan 15, 2009 | 12:55 PM
Lazy K's Avatar
Lazy K
Can`t see how the two things could possibly be connected. My guess is thatthe transfer case is stuck in neutral and a brake line failed at the same time.
Good luck.
Old Jan 19, 2009 | 11:08 PM
billy12360's Avatar
billy12360
i would figure a vacuum leak of some sort....
Old Jan 21, 2009 | 09:19 PM
paredneck33's Avatar
paredneck33
I've got the perfect solution, tell him to junk the chebby and buy a FORD. but seriously it sound to me like a vaccum prob.
Old Jan 22, 2009 | 09:14 AM
5_labsownus's Avatar
5_labsownus
You may go to www.chevytalk.org and ask them for help.
Old Jan 22, 2009 | 08:50 PM
93F250's Avatar
93F250
I guess he decided the tranny was toast. Not sure how he came to that conclusion.
Old Jan 23, 2009 | 07:58 PM
rebocardo's Avatar
rebocardo
I had a long post to tell of the problem and how it most likely happened when the database crashed.
Basically, considering you are in Maine here is how I think both failed at the same time.
He was rocking to get free in snow, he toasted reverse. While backing up he smashed into packed snow/ice and crushed the rear hard line that goes over/in front the diff. on some Chevys and Dodges. Or he hit packed snow so hard he ripped the rubber line off the rear axle.
One of the major advantages of the Ford 9" axle was the steel line L 2 R was mounted at the top of the axle so you did not nuke it off road backing into something.
So, when doing snow driving where you plan on ramming back and forth to create a path through deep snow, it does not hurt to mount the hard lines above the axle where they are better protected. Plus on Fords mount the shocks higher and cut the mounts off flush with the axle.
Old Jan 24, 2009 | 08:02 PM
93F250's Avatar
93F250
It's very possible. I posted what little I know. The truck has over 200k on it and he runs it pretty hard and doesn't keep on maintainence so he had it coming.
mdula
35
Nov 3, 2018 09:18 AM
mastercrack61
1978 - 1996 Big Bronco
Dec 4, 2014 10:41 PM
MADSEN
Apr 30, 2011 07:14 AM
pud
Dec 29, 2008 02:21 AM
i eat hybrids
Jan 2, 2008 08:41 AM
