2 1/2" or 3" pipe
Old Oct 16, 2002 | 11:12 AM
kevinrf250's Avatar
kevinrf250
2 1/2" or 3" pipe
I have a 1994 F-250 with a 460 and am redoing the whole exhaust system. I have a set of Hooker Supercomp ceramic coated headers on the way. In my great state of Montana we have no emesions testing so I am not going to run any cats. I plan on doing a true dual exhaust with an H-pipe and Flowmaster Delta flow 50 series mufflers with 3 1/2" tips. My question is weather to run 2 1/2" or 3" pipes? I have heard good and bad things about both. Any recommendations would be nice.
Old Oct 16, 2002 | 02:33 PM
heathdaily's Avatar
heathdaily
2 1/2" or 3" pipe
If you're gonna tow and/or do truck stuff. Go with 2 1/2 it'll keep flow and exhaust scavenging up in a usable rpm.
If you're gonna run a street terror. Go with 3 it'll keep flow and exhaust scavenging up at a high rpm.
If you want both, run 3 from header to muffler, then 2 1/2 from muffler to exit. The front section of pipe is most important to exhaust scavenging. As the exhaust pulses travel down the pipe they tend to slow down and blend together. The muffler increases this. Therefore the smaller pipe after the muffler can help increase flow speed without becoming a restriction. It's also much easier to get over the axle. Your exhaust man will appreciate it anyway.
Most header come with super el-cheapo gaskets. Find something better. I personally like the fel-pro blue. Whatever you get, read the instructions if they have any, and remember to recheck/retourque often while breaking them in.
Old Oct 16, 2002 | 02:51 PM
GOT NOS's Avatar
GOT NOS
2 1/2" or 3" pipe
i would run 3in because it sounds better and people say that it takes away your torque but i havent really felt it ruch im running a small block with 10.1 compression 498lift cam 750 double pumper edlebrock performer rpm manifold i shift the truck 7000 rpm i love the 3in exhaust its a lot deeper sound and louder than 2 1/2 in, i love it my buddy had a stcok 454 and ran 3in and couldn't tell a diffrence in tourqe come on its a big block it sounded awsome and it was a stock motor.
Old Oct 16, 2002 | 07:36 PM
fordtruckin's Avatar
fordtruckin
2 1/2" or 3" pipe
2.5" will be fine for a close to stock motor. The only way you'd need 3" is if you do a pretty radical build on it.
Old Oct 20, 2002 | 08:57 AM
85351ho's Avatar
85351ho
2 1/2" or 3" pipe
dont put 3 inch duals on a stock motor, even a 460...its a waste. 2.5's will suit ya fine.
Old Oct 20, 2002 | 08:59 AM
85351ho's Avatar
85351ho
2 1/2" or 3" pipe
Aune163rd
29
Apr 23, 2011 01:47 AM
MDBENDER
May 10, 2008 09:37 AM
encourager
Jul 10, 2007 11:14 AM
gunfighter1
17
May 13, 2006 03:15 PM
Burnt 1
Modular V10 (6.8l)
Dec 21, 2003 07:14 AM
