76 F-150 300 In Line 6, Stalls,idle Issue
Good day all, new here. Great responses to all issues!
I have a in line 6, 300 76 f-150,176000 MILES, SSI, 3 on the tree, man steer, power boost brakes....
Idles poorly, will run if i keep idle up at 900-1000, with a vibration. will stall coming to a stop. starts ok cold. I HAVE REPLACED plugs, wires,coil, cap,
button, all filters fuel(at carb) air, oil, sprayed cleaned carb, ran 2 tanks w/lucas fuel treatment, still runs rough.
not sure on carb, heater valve in exhaust, or valve adj
Looks like a carb / rebuild is next !?![Huh?](images/smilies2/confused.gif)
any thoughts?
thanks
any thoughts?
thanks
on
The 300-6 didn't use exaust manifold gaskets originally. Only an intake gasket. The exaust manifold to head should be metal to metal.
There are aftemarket gaskets that have a exaust manifold gasket built into the intake gasket. Using these types of gaskets will increase the gap between the intake manifold and the head which can cause potential leaks.
If you use the aftermarket intake/exaust manifold gasket, you need to seperate the intake and exaust manifold from each other, then realign them for the new type gasket.
Exaust On 76 300-6
This weekend I am going to tear down the old girl again,
looking for the leak. best to go- no go with a gasket?
she is better but still will stall / stumble coming to a quick stop / more so if DOWNHILL. carb float??
never have rebuilt this one - or any for that matter, simple one i hope, or replace with reman / new. any thoughs guys?
thanks.
on
The Carter Motorcraft YF carb is the simplist carb to rebuild. You can take it apart and rebuild it in about two hours. Just make sure you take the time to clean the carb. This can take longer than two hours depending on how dirty. ![Wink](images/smilies/wink.gif)
As for the intake gasket, you should use the intake gasket that came stock with it. The one without the exaust manifold gasket.
Well I found my AROUND2IT, carb clean and with the FLOAT turned upsidedown ( the way it shows in several pics ! ) she LIVES. NO MORE stalling at a stop, idles good, 17" vac and steady. better pick-up, I need to adjust choke a bit but all seam fine.
THANKS to all the input!! looking for tune-up details, NO engine decal to go by. will start a new post on this.
1984Ford300six
15
08-23-2014 08:54 AM
eriklane
05-11-2014 04:12 PM
old ford user
01-22-2012 10:08 PM
Madsan
10-07-2010 05:18 AM
Mally106
01-17-2007 03:41 PM
