C6 left outisde
Old Jan 10, 2009 | 05:34 PM
mlevario99's Avatar
mlevario99
Exclamation C6 left outisde
When I took out the engine (FE390) from my truck I left the transmission outside uncover, I'm in the process of installing the engine again, what do I have to do to clean the transmission, do I need to remove the cover that is located at the front of the transmission, where the converter engages.
Thanks
Old Jan 10, 2009 | 08:47 PM
mark a.'s Avatar
mark a.
I wouldn't worry about it. If you take the pan off it to drain the fluid I wouldn't turn it on it's side or upside down though, all the crap in the bottom of the pan will go up in the trans.
Old Jan 10, 2009 | 08:53 PM
393STROKER's Avatar
393STROKER
Exclamation
Remove rust on input shaft w/wire brush and WD-40,put new front/back seals in,change filter.
Old Jan 11, 2009 | 03:42 PM
rclarke's Avatar
rclarke
If the transmission just got rained on its probably ok as said above. But, if there is water inside the transmission I would replace all the friction plates which is the same as an overhaul. The friction plates won't tolerate water.
Old Jan 11, 2009 | 08:08 PM
mlevario99's Avatar
mlevario99
Well, we didn't have any rain, what I was worried it was dust getting into the transmission, but I guess that is why they have the seals, correct.
Thanks for all your help.
4inchlovin
May 6, 2009 05:08 PM
4inchlovin
39
Apr 24, 2009 03:31 PM
rustychip
Aerostar
Nov 20, 2005 06:20 PM
dryul
Aerostar
Jul 8, 2004 09:45 PM
milkman00
Nov 1, 2001 12:53 PM
