Torqshift question?
Old Jan 10, 2009 | 08:59 AM
400m's Avatar
400m
Torqshift question?
Hey guys, I just recently purchased a 2006 f-250 king ranch powerstroke and having previously owned a 97 powerstroke with the e40d transmission in it are there typical problems, items to watch out for or words of advise regarding the torqshift transmission behind a 6.0 psd?
Thanks
Old Jan 10, 2009 | 09:41 AM
strokin83's Avatar
strokin83
The only things I would suggest are 1. Never put anything other than Mercon SP fluid in it. And 2. Always use the tow/haul button while towing. My 05 has 124,000 mostly towing miles and it still shifts like it's new. It is a great transmission. Good Luck
Old Jan 10, 2009 | 10:24 AM
UGA33's Avatar
UGA33
The 5R110 is the best tranny in the segment. Yes, its better than the Allison. When properly tuned, these trannies can hold upwards of 600-650 rwhp and survive. They are great transmissions and like mentioned above, only Mercon SP! The 04's had an issue with bad snap rings (I think, someone correct me if im wrong) but that was resolved.
Old Jan 10, 2009 | 11:14 AM
bismic's Avatar
bismic
Change the fluid and external filter every 30k.
The external filter (FT-145 or part # 3C3Z-7B155-BA OR aftermarket filter NTZ09-C09B) is behind the passenger side front bumper. I used an impact wrench to get the filter housing off to avoid twisting lines. It takes a 7/8" socket. You will lose very little fluid through changing the filter - only a few ounces.
To change the fluid, you can either drop the pan, drain, and refill, or you can flush it. If you have it flushed, it must be done with a heated machine (170 *F minimum) to open up the internal thermostat (more than 90%) to get the torque converter flushed also.
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>If you drop the pan and the internal screen is clean, do not change. It only stops trees and boulders. Gasket is reuseable if not damaged.
</TD></TR></TBODY></TABLE>
As was said ....... it is a great transmission! Also - do not switch "to and from" Reverse without stopping completely. It needs just the basic care and PM and it should treat you very well.
Old Jan 10, 2009 | 12:07 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
The torqshift is a great tranny. It's probably the least discussed item on this board from a problem perspective. Additionally, the tow/haul function in connection with the 6.0 is awesome.
I just hit 60k miles and am trying to decide whether to flush or drain and fill along with replacing the external filter. I had the dealer flush it at 30k and have only towed a couple times (6000 lbs) in the last 30k. Decisions, decisions.
Old Jan 10, 2009 | 01:49 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I believe the book says to change your tranny fluid every 30,000. Shouldn't even have to ask the question....look at your users manual. If you don't have it, it's downloadable from Ford's web site.
Old Jan 10, 2009 | 01:58 PM
doubledee715's Avatar
doubledee715
Originally Posted by bismic
Also - do not switch "to and from" Reverse without stopping completely..
Why not? ?
Old Jan 10, 2009 | 05:50 PM
400m's Avatar
400m
Well it sounds like ford made up for the problems with the E4OD. It is a good thing to know that this is a very stout tranny. My truck has 70k milies on it and from what I can tell I don't think it ever towed a thing before I bought it. All the miles are Nebraska and Iowa open road miles. It does seem to shift slow compared to my 97 f-250 which had nice quick firm shifts. All the info is great I hope this truck is as solid and strong as my 97.
400m
Old Jan 10, 2009 | 07:36 PM
bismic's Avatar
bismic
Originally Posted by doubledee715
Why not? ?
I have always been taught this AND just recently was told it again by the person that upgraded my son's 7.3L tranny. He said that this was the most common way to damage a transmission. I never checked into the mechanism for damage - hmmm, usually I am more curious than that. I guess I will have to get a technical answer from him when we go get my son's dptuner adjusted slightly for better shifts w/ the new tranny.
Old Jan 10, 2009 | 10:57 PM
bismic's Avatar
bismic
BTW - the owners manual states to come to a complete stop before shifting into reverse. It also states to not "rock" between Reverse and Drive for more than 1 minute or damage may occur.
Old Jan 10, 2009 | 11:18 PM
jetact's Avatar
jetact
not very happy with the trans
Well I have an 05. I have 44870 on my truck. I just spent $5,483.52 on a rebuild. Yes I thnk the snap ring is now fixed in anything after 02/05 but that didnt help me. It was recalled if you had the plow package. It is the same trans and everything but an option changes something, I dont think so. Ford should have repalced eveyone of the snap rings that were bad. Not just some lame excuse if you have a plow. My snap ring broke and took the case with it as well as smoe metal that went through a bunch of things. I am not happy at all. A truck with such low miles should not have this problem and expense. As you can see from my pictures. I take very good care of my truck and give it everything it need and more.
Old Jan 10, 2009 | 11:30 PM
bismic's Avatar
bismic
Sorry to hear of your expensive troubles. One thing to consider would be send an email to Ford complaining about it. My son has a 2005 F150 and just spent $600 to get the spark plugs changed due to a poor design. Ford approved some compensation and referred him to the dealership that did the work. He ended up with $150 credit. Still should not have happened - but every little bit helps.
<TABLE style="WIDTH: 506pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=675 border=0 x:str><COLGROUP><COL style="WIDTH: 506pt; mso-width-source: userset; mso-width-alt: 24685" width=675><TBODY><TR style="HEIGHT: 15.75pt" height=21><TD class=xl26 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" width=675 height=21>Ford Motor Company</TD></TR><TR style="HEIGHT: 26.25pt" height=35><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 26.25pt; BACKGROUND-COLOR: transparent" width=675 height=35>Customer Relationship Center</TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" width=675 height=21>P.O. Box 6248</TD></TR><TR style="HEIGHT: 26.25pt" height=35><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 26.25pt; BACKGROUND-COLOR: transparent" width=675 height=35>Dearborn, MI 48121</TD></TR><TR style="HEIGHT: 26.25pt" height=35><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 26.25pt; BACKGROUND-COLOR: transparent" width=675 height=35>1-800-392-3673 (FORD)</TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" width=675 height=21>(TDD for the hearing impaired:</TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" width=675 height=21>1-800-232-5952)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=675 height=17 x:str="www.customersaskford.com ">[FONT='Times New Roman', serif]www.customersaskford.com [/FONT]
I had been looking for the year that they fixed the snap ring. I thought it was in 04 - so thanks for the post.
Old Jan 10, 2009 | 11:55 PM
sonneborn3's Avatar
sonneborn3
<TABLE style="WIDTH: 506pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=675 border=0 x:str><COLGROUP><COL style="WIDTH: 506pt; mso-width-source: userset; mso-width-alt: 24685" width=675><TBODY><TR style="HEIGHT: 15.75pt" height=21><TD class=xl26 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" width=675 height=21></TD></TR><TR style="HEIGHT: 26.25pt" height=35><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 26.25pt; BACKGROUND-COLOR: transparent" width=675 height=35></TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" width=675 height=21></TD></TR><TR style="HEIGHT: 26.25pt" height=35><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 26.25pt; BACKGROUND-COLOR: transparent" width=675 height=35></TD></TR><TR style="HEIGHT: 26.25pt" height=35><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 26.25pt; BACKGROUND-COLOR: transparent" width=675 height=35></TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" width=675 height=21></TD></TR><TR style="HEIGHT: 15.75pt" height=21><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" width=675 height=21></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 506pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=675 height=17 x:str="www.customersaskford.com ">
I hope they fixed it for 04, that is what year mine is, and that story was pretty scary!!
Old Jan 11, 2009 | 12:34 AM
PowerStrokeHD's Avatar
PowerStrokeHD
The snap ring issue only affected 05's (w/ snow plow package) according to the info I have. The reasoning (according to Ford) behind the focus on the snow plow package equipped trucks is it is common for them to repeatedly and sometimes rapidly shift between forward and reverse which could cause the snap ring to rotate out of position and become unseated. It affected diesels from '05 Job 1 through 01/12/05 and gassers from '05 Job 1 through 01/14/05.
The issue with the 04's involved replacement of the reverse planet assembly due to low/reverse gear set pinion shaft(s) that may walk out. Vehicles affected were built from 03/08/04 through 06/24/04.
Old Jan 11, 2009 | 12:46 AM
sonneborn3's Avatar
sonneborn3
Ironically, mine was built 1-11-04, so it sounds like I am safe. I wonder what to get my baby for her 5th birthday today? The bad part, is that the 5 year 100,000 mile warranty just expired, I guess it's time for that EGR delete!
Sorry, not trying to hijack the thread, just got carried away.
scup27ri
Dec 21, 2010 07:52 PM
brickie
Apr 27, 2009 09:02 PM
Calf_roper_John
Jan 1, 2008 12:30 AM
PowerStroke King
Ford vs The Competition
76
Jan 26, 2005 08:38 AM
FTE Ken
Site Announcements
Jun 5, 2002 11:43 PM
