Sponsored by: Auxito
Block heater
Old Jan 29, 2009 | 12:01 AM
  #31
1Fordnatic's Avatar
1Fordnatic
Yea-with the 1500 watt ones it will heat up and start quick. The thing you have to watch is that it will start instantly even with a short pre-heat-but the oil is still really cold-hasn't had time to pick up any of the heat from the coolant and is very thick and won't lube well at all. Synthetic oil helps with this.
Old Jan 29, 2009 | 06:32 AM
  #32
jimm66's Avatar
jimm66
That is very true especially where you are. We only have a few days below zero. I think we are up to 17 days below zero, but we are colder than normal this year. I always use ford synthetic blend.
Old Jan 30, 2009 | 07:41 PM
  #33
Gunsmoke9150's Avatar
Gunsmoke9150
External Block Heater
Yes it has two fittings for heater hose connection.
the instructions tell you to connect the top fitting into a heater hose and a "Y" connector is provided in the kit. That is the easy part.
The bottom fitting is supposed to connect to a fitting, screwed into the block thru a freeze/drain plug. There is a perfect spot on the Drivers side of the 5.4 V8 but the heater hoses are all on the passenger side of the engine. I could make it work but the plumbing would be a mess. I was hoping that there was a similar freeze/drain plug on the passenger side of the engine to tap into. It would still be ackward with the starter and A/C unit on that side but it might be able to make it work. But I cant find a suitable freeze/drain plug on the passenger side.
I suppose it would work to tap into the two heater hoses but the circulation might be limited to the heater core and really not flow thru the block.
I will keep studying it.
Thanks
Old Feb 2, 2009 | 04:12 PM
  #34
KingRanchMan02's Avatar
KingRanchMan02
Old Feb 3, 2009 | 09:57 AM
  #35
KingRanchMan02
What I was trying to post was this. www.padheaters.com
MarauderV8
Dec 17, 2014 01:44 PM
jakpine
15
Dec 18, 2009 08:40 PM
web4elk
15
Dec 19, 2007 06:56 PM
Pablo-UA
Aerostar
15
Dec 2, 2007 02:40 PM
viperrtblck
Dec 7, 2006 07:56 AM
