Sponsored by: Auxito
Block heater
Old Jan 16, 2009 | 01:13 AM
tripledeuce's Avatar
tripledeuce
Apparently so. Mine has had one since the day I drove it off the lot.
Old Jan 16, 2009 | 03:41 AM
78bigbronco's Avatar
78bigbronco
Mine has a plug and I've never used it before.
I remember back when I first came to ohio - grew up in upstate NY (by the st. lawrence river) had an 85 corolla SR5 and had a plug hanging out the grill for the block heater. Would use it when the temps hit neg teens (if i rcall even saw a couple days in the -30's when I was a junior or senior in HS). Of course that thing was carberated and with a wimpy starter so it needed some help when it got down below -10 or so. When I came to Ohio no one even knew what it was. people saw the plug and asked if I had an electric car. Yeah... toyota made an electric corolla in '85
Old Jan 16, 2009 | 08:27 AM
jimm66's Avatar
jimm66
I think they all had them from factory or most did. Not sure of what years.
Old Jan 16, 2009 | 10:25 AM
KingRanchMan02's Avatar
KingRanchMan02
If I am not mistaken, the engine block heater is an option on the order sheet that dealers in the northern states would most likely check that option off on all the vehicles ordered. I wouldn't expect it to cost much.
Old Jan 16, 2009 | 12:26 PM
Club Wagon's Avatar
Club Wagon
In '98 the block heater was not "an option" as such, it was a dealer installed accessory "Base Part Number - 6D008". My Dad's paperwork indicates it cost $28, but its not clear how much it cost installed. The '98 FORD Accessory Catalog claims "faster cold weather starting with less fuel waste and battery drain" & "Helps passenger compartment heater deliver warm air sooner."
We expect a record low temp overnite, but I don't plan on ever using the block heater here in FL. The temp may dip below 20, I'll be picking grapefruit so they don't freeze.
Old Jan 16, 2009 | 12:40 PM
jimm66's Avatar
jimm66
NO you never need a block heater in fl. Save that crop. Noon and we are still below zero. Good luck.
Old Jan 16, 2009 | 02:52 PM
1Fordnatic's Avatar
1Fordnatic
Originally Posted by jimm66
I just watched the weather and we had 22 below yesterday and not sure how far we are going this am. You warmed up and we got your weather.
Your right, it got warm enough in Anchorage to make a huge mess. Roads were closed, people were told to stay home from work, and schools closed. Water on ice is not fun!
Luckily I am still at work far north of the arctic circle, it only got just above zero here. Enough to make it really nice-but not cause the problems.
Old Jan 16, 2009 | 03:37 PM
BLK94F150's Avatar
BLK94F150
So do they or do they not all have block heaters. My truck made a terrible noise starting at -8 this morning. I think that's the coldest I've ever started it.
Mike
Old Jan 16, 2009 | 04:06 PM
KingRanchMan02
No all of them do not.
Old Jan 16, 2009 | 04:57 PM
1Fordnatic's Avatar
1Fordnatic
I have found it on some when the owner didn't know it was there. Look for an electrical (110) cord rolled up and tied somewhere near the battery.
Old Jan 17, 2009 | 07:51 AM
Spotty's Avatar
Spotty
We just came off of -30 below stuff. My work truck sits outside all year long, it is a 98 F-150...4.6, automatic. 4 hours is good enough, although I have found that if I leave it plugged all night, even the power steering is good right at startup. If it is going to be below 0 I will plug it in. I have forgot, and it starts OK at -20, but sounds awful!!!! My truck is 11 years old, has spent all it's life outside in Minnesota...it still has the original battery from 98. Other than pull the oil and filter every 3000 miles, along with normal maint., that's about all I've done to it. My 97 Mustang GT is a garage queen, only brought out on nice summer days, it has had 3 batteries. Daily driving is still one of the best things for longevity.
Old Jan 26, 2009 | 09:55 PM
Gunsmoke9150's Avatar
Gunsmoke9150
External mounted block heaters
looking for info on the OEM Plug type block heater. I am assuming it is simply an element that screws into a freeze plug and then has a 110v cord hanging out to plug in. Probably rated at 1000 watts max.I have an external heater procured after market. Looks like a beer can with two tube nipples. One is supposed to go to a fitting in the drain/freeze plug and the other splices into a heater hose.On the 5.4, the obvious place to mount the can is on the passenger side of the compartment as the heater hoses are on that side but I cannot find a freeze plug or drain plug to tie into. There is one on the drivers side of the engine but that makes the plumbing real messy.do the small freeze plug type heaters really work on this big engine?thanks
Old Jan 27, 2009 | 05:06 AM
  #28
jimm66's Avatar
jimm66
The oe heater is on the rear freeze plug driver side. I doubt if they are 1k watt maybe more like a couple hundred not really sure. How many watts are the one you have?
Old Jan 27, 2009 | 08:39 PM
  #29
Gunsmoke9150
Block heater
The canister one I have is advertised at 1500 watts. Im sure I dont need that much in MI but I was hesitant to go with the freeze plug ones because they are rather small for a big block.
Just cant seem to come up with a good clean mounting system. I may have to go with the OEM type.
thanks
Old Jan 28, 2009 | 06:06 AM
  #30
jimm66's Avatar
jimm66
Doesn't that canister have an in & out? I thought those were suppose to tap into a heater hose. 1500 watts sounds high don't think that needs to be on very long.
