97 block heater
Old Dec 4, 2006 | 08:38 AM
viperrtblck's Avatar
viperrtblck
97 block heater
block heater isnt workin on my 97? gonna try a different extension cord first, but if that fails still, i'll replace teh block heater cord, and if THAT fails, then replace the actual block heater itself. wondering if anybodies done this before on a 97 or model year similar to it. if so, how involving is it and how much trouble am i going to be in if i have to replace the block heater? how long does it take and stuff?
thanks
Old Dec 4, 2006 | 08:41 AM
1996pwrstrk's Avatar
1996pwrstrk
I have never changed one but before you change the chord check the plug mine was shot I replaced it with a weatherproof one nomore cold truck.
Dave
Old Dec 4, 2006 | 10:17 AM
viperrtblck
Dave
what plug are you talking about? the actual three prong electrical connector that plugs into the extension cord? check that plug?
Old Dec 4, 2006 | 11:40 AM
viperrtblck
what/where is the actual block heater itself anyways? i looked here at college on all data and it's showing an object that the cord plugs into directly above the oil filter, i looked on teh truck and there is what looks to be a brass object threaded into there. about 1 1/2 inch diameter. all data said this was the block heater? is that true? that small and simple?
Old Dec 4, 2006 | 11:42 AM
1996pwrstrk
I'm sorry, yes the three prong plug one of my wires was broken inside the insulation . I just cut it off and replaced it. As far as I can tell yes that's it, of course you will have to drain your coolant before you pull it out.
Dave
Old Dec 5, 2006 | 07:52 AM
viperrtblck
Dave
maybe ill try a new plug first, how far in did you cut the old one off, how did you knwo one of the wires was shot? and which wires go where on the new plug?
Old Dec 7, 2006 | 07:56 AM
viperrtblck
anybody know which wires go where on the new plug?
Restlesswildman
Nov 16, 2014 07:09 PM
drivembig
17
Jan 11, 2010 04:36 AM
GreatWhite99
Jan 5, 2010 09:28 PM
hunting247
Dec 15, 2009 04:58 PM
FordTruckNoob
Dec 29, 2008 02:22 PM
