Did you get my email through FTE? You don't seem to have your PM privelages enabled.
Yes the PCM is by the e-brake below the fuse box. The connector is on the engine side of the firewall. Look at the first pic in this link (borrowed from Jody & Diane) and it will show you what you need to disconnect to test the wiring. http://www.dp-tuner.com/wordpress/wp...stallation.pdf
