Help please
Old Jan 14, 2009 | 08:15 PM
  #31
F350-6's Avatar
F350-6
Did you get my email through FTE? You don't seem to have your PM privelages enabled.
Yes the PCM is by the e-brake below the fuse box. The connector is on the engine side of the firewall. Look at the first pic in this link (borrowed from Jody & Diane) and it will show you what you need to disconnect to test the wiring. http://www.dp-tuner.com/wordpress/wp...stallation.pdf
Old Jan 14, 2009 | 08:48 PM
  #32
stew7.3's Avatar
stew7.3
Chris, I'll be out of town Thurs. but will check to ground connection asap. Thank-you very much for all the information, as well as to everyone else!
