E4OD 40K mi rebuilt problem
Old Jan 8, 2009 | 05:12 PM
POWERSMOKIN's Avatar
POWERSMOKIN
I have an E4OD with 40K miles on a fresh rebuild. when at operating temp, the trans will not shift out of first, until i rev it high then let off, or go all out. when it shifts going all out, i believe it skips 2nd and goes straight into 3rd. I read that an intermediate clutch pack could be causing this problem.
on top of that, when in OD when hot, it will not pull out of OD when the button is pressed. it will stay in OD until it revs down to ~900RPM then will violently go into first, over-rev, and go back into 4thOD, back and forth till i have to pull over and start over.
took it to a (bad) oil changer where they just sucked the fluid out with an evacuator, and re-filled it. still problems persist. he did say though that he picked up chunks of black stuff, which could be remnants of the clutch.
Any input on this problem is appreciated.
PS, hey im over from the ORG. seeing if another forum can give me any help.
Hello Yall!
PSS I cant find how to fill out my sig. its a 1996 F350 CC LB
Old Jan 8, 2009 | 05:19 PM
foxracing0934's Avatar
foxracing0934
Welcome to FTE stick around and im sure someone will come up with the answer. I am by no means a guru but one thing that i seem to read about fairly often is the TRS (transmission range sensor i believe). But someone else will be along with a more definitive answer
Old Jan 8, 2009 | 05:26 PM
POWERSMOKIN
what does the TRS do? and would a scanner pick that up? cause scan was clear.
Old Jan 8, 2009 | 06:30 PM
kawa's Avatar
kawa
The reason you can't post your signature is because you have to post
X-number of posts. I don't recall how many but I think it's around 200-250.
A tranny Guru will jump in here soon enough and will give you sound advice.
ROG
Old Jan 8, 2009 | 07:34 PM
F350-6's Avatar
F350-6
No tranny guru here, but I'll bump you back near the top. When they did the rebuild, did they install an inline filter like a Magnafine in the cooler hose? If so, I'd change it out, then cut the old one open to see if there are any more "chunks of black stuff" in there.
Are you running a chip in the truck? Have you installed a shift kit or anything? My experience has been if you take it to a shop that just drops in a rebuild, it's a crapshoot at best.
I believe it's 25 posts before you can have a sig.
Old Jan 8, 2009 | 07:58 PM
c00nhunterjoe's Avatar
c00nhunterjoe
first question is do you have a warrenty on the tranny?
second is did this happen all at once or get progressivly worse? any other issues up until this problem?
what does it do when the fluid is cold?
why did you get the tranny overhauled to begin with?
is it a remanned trans or did you get the origonal unit overhauled?
it really sounds like its time to remove the tranny again
Old Jan 8, 2009 | 11:14 PM
POWERSMOKIN
I do not believe so. I am second owner of rebuilt tranny in the truck.
second is did this happen all at once or get progressively worse? any other issues up until this problem?
Progressively got worse, about 2 months ago, it started with not coming out of OD.
Works fine, not one problem. although at steady 3/4 pedal, the 1-2 shift is alittle softer than all the rest, OD disengage works fine.
Previous owner did it. Truck has 210K miles.
I do not know. All documentation shows Carquest: E4OD xxxxxxxxxxx (S/N i believe). sales sheet on the window and craigslist said Rebuilt E4OD transmission 33K miles ago with new HD torque converter.
I have NO tranny experience. Im going to take it to a shop.
Old Jan 8, 2009 | 11:36 PM
ron86toy's Avatar
ron86toy
I have an auto but not a guru on it....If you are going to have it rebuilt I would be looking into a BTS,john woods or racerx for it since they all specialize in these....I will be going to BTS as a personal pref.
the other guys will be along that know these much better......I would shoot Mark a PM too
https://www.ford-trucks.com/forums/member.php?u=23422
Old Jan 9, 2009 | 06:15 AM
Cuda_jim's Avatar
Cuda_jim
I'm no tranny expert either but just changing the oil and not the filter is a bad idea IMO. Drop the pan, change the filter, refill and see if it gets better. It's easy and cheap so it's not that much of a gamble.....maybe $30-35.
I seriously doubt they "picked up chunks of black stuff". Did they show them to you? IIRC the fluid is filtered before it leaves the trans.
Old Jan 9, 2009 | 02:53 PM
Joe_D's Avatar
Joe_D
Yes, the pan needs to be dropped so you can clean all the gunk off the magnet as well.
Old Jan 9, 2009 | 05:45 PM
POWERSMOKIN
Im not going BTS. i dont have $4000. If its the intermediate clutch, its 700. and all im gonna run is stage 1 rosewoods. the trans should handle that.
im gonna take it to golden gate transmissions. have them look at it for free. no point in re-doing the fluid iif there gonna change it when there in there anyways.
Old Jan 9, 2009 | 07:02 PM
lossscause's Avatar
lossscause
Last time I called Brian's, the base price was $4100 + you shipping your tranny there and him shipping it back. Are you in Cali? Then I would say it would be closer to $5000 if you can't drive there and let him install it.
If the place you had the oil changed really did find black chunks of something, then I would be willing to bet you'll be into it for more than just an intermediate clutch.
When I knew mine was going out, I took some time and talked to ALOT of tranny shops around town (after I decided I couldn't afford a BTS), and found a small shop with a great reputation, no b.s., and a solid warranty. They are hard to find, but they are out there.
Good luck. Let us know what you find out.
Old Jan 9, 2009 | 08:21 PM
pjwoolw's Avatar
pjwoolw
Tranny shop
I guess you have previous experience with Golden Gate. I don't. I had mine done by Shucks in Dublin. I wouldn't recommend them. A little over three grand for the rebuild. Time will tell on reliability. PM me if you need some hands on help or advice. I'm in San Ramon.
Good luck with it.
Pete
Old Jan 9, 2009 | 09:04 PM
c00nhunterjoe
with the issues you are describing, lack of history on the tranny, amount of time you have been driving it like that, throwing a single component at it would be ridculous in my opinion. slipping shifts when cold, no gears when hot? think about what you are saying you want to do..... the fragments of whatever let loose have been traveling all over your tranny, all through the other clutches, all through the thrust washers....... you would be wasting your time and money to do what you suggested. odd are that is exactly what the place did that overhauled it, simply replaced a lone damaged clutch or band, didnt do a proper overhaul. but its your money and your truck so all i can do is offer advice
Old Jan 9, 2009 | 11:50 PM
POWERSMOKIN
I talked to Kwik Shift, no good. My shop teacher, Mike Spragge recommended golden gate. when he worked for ford, and had his honda shop, thats where he would send all of his trannys.
pjwoolw i was just there tonight at zacharys pizza! well have to do a GTG some time.
coonhunter, well have to see what they say... i think theres gonna be a lot of problems.
ml8on
1978 - 1996 Big Bronco
15
Apr 23, 2014 11:58 AM
dieselaholic
Dec 29, 2011 02:26 PM
jWoDal
Aug 28, 2011 04:10 PM
fteduran
2004 - 2008 F150
Jul 25, 2010 03:59 PM
aero92
Aerostar
17
Mar 18, 2008 08:40 PM
