E40D OD SPRAG
Old Aug 19, 2011 | 04:28 PM
jWoDal's Avatar
jWoDal
E40D OD SPRAG
Ok i rebuilt my e4od took it for a ride and it shifted fine untill it tried ot come out of od it seemed to hold the truck back untill it came out of 4th. Then it strated to make whirling sound. I pulled it out and found out that the od sprag came apart and the rollers are all jamed up and the plastic cage is chewed up. My question is that could this just of been a faulty od sprag or could of there been other factors to cause this problem? Thaks
Old Aug 20, 2011 | 09:17 AM
jk080's Avatar
jk080
Transmission Rebuilder
The overdrive sprag has to hold during a forced 4-3 downshift, I think based on what you described that it just let go.
Clean it up and give it another try, hopefully you will have some better luck this time.
Old Aug 20, 2011 | 03:15 PM
jWoDal's Avatar
jWoDal
Thanks alot I'am new at rebuilding transmissions and just want to make sure that nothing elese would of caused this.
Old Aug 28, 2011 | 11:20 AM
jWoDal's Avatar
jWoDal
Is it possible that when the od one way clutch locked up it would of burnt the od and the coast clutch packs
Old Aug 28, 2011 | 04:10 PM
jk080's Avatar
jk080
Anything is possible when something like that fails, I would double check everything while you have it out.
Seattleslow
Mar 3, 2017 12:22 PM
quincyj34
Jan 4, 2014 07:54 PM
Tibbits
Oct 17, 2009 01:34 PM
dentvet
Feb 23, 2008 03:37 PM
