E4OD shift
Old Jan 6, 2009 | 02:11 PM
Cdy1's Avatar
Cdy1
E4OD shift
i have a 95 5.8 e4od bronco, some times it shifts hard 1st-4th iv changed the VSS, what els can i check?
Old Jan 6, 2009 | 08:52 PM
tbirdscott's Avatar
tbirdscott
Check your MLPS it is the shift position sensor, it is on the drivers side of the tranny around the shift lever. Mine was dead, had no back up lights and was shifting hard all the time. Also go through all electrical connectors you can find with some di-electric grease.
Have you checked for codes yet? EEC IV Self Test hookup
Scott
Old Jan 6, 2009 | 09:43 PM
Cdy1's Avatar
Cdy1
yeah i have a reader gave me VSS signal fault... but i replaced it and it only shifts hard sometimes.. =/
Old Jan 7, 2009 | 03:27 PM
jk080's Avatar
jk080
Transmission Rebuilder
You must clear the code after the repair, try disconnecting the battery(s) for about 5 min and then try it.
Old Jan 7, 2009 | 09:35 PM
Cdy1's Avatar
Cdy1
i did, i think you told me too last time i asked lol, but if it tells you anything sometimes the light will flash to give the code n sometimes it wont
Old Jan 8, 2009 | 08:31 AM
jk080's Avatar
jk080
Yea that's funny, at least I am consistent.
If its still setting the code it may be losing connection between the sensor and computer, check all wires and connections. What is the code number?
I had one a few years ago that drove me crazy and it turned out to be the cruise control module.
Old Jan 8, 2009 | 02:34 PM
Cdy1's Avatar
Cdy1
code is... 452(koEo)
Old Jan 10, 2009 | 08:55 PM
jk080's Avatar
jk080
I have found a few cases where the PSOM was the cause of intermentant loss of VSS signal.
Photo 1 is a view of the speedometer cluster that we are all accustomed to seeing. Photo 2 is the PSOM attached to the rear of the speedometer cluster. At the bottom of the PSOM, there is a ribbon cable similar to what you would see in some printers. A PSOM that intermittently loses its signal can be traced to a partially dislodged and / or dirty ribbon cable connection. It is recommend using Isopropyl Alcohol and the brand name Q-Tips to clean the ribbon cable connection. In addition to ribbon cable concerns, there have been circuit board issues as well. You can sometimes see a burned spot on the circuit board if you examine it under a strong light and use a magnifying glass. If you ever remove a speedometer cluster and there are obvious signs that the PSOM has been contaminated with rain water, soda, coffee, etc., it is recommended to replace the PSOM assembly as opposed to cleaning as cleaning under such circumstances have not proven successful for long term repairs.
Old Jan 10, 2009 | 10:06 PM
Cdy1's Avatar
Cdy1
hmm.. i just learned somthin lol ill do it prolly tomorrow, n ill post back i sure do hope it works =]
Old Jan 11, 2009 | 02:33 PM
Cdy1's Avatar
Cdy1
i tried to pull it out to do that but... its my only vehicle and i cant aford to break somthin, any pics or anything about takin it out? the plugs in the back should i be worried about breakin thos or just pull em out
Seattleslow
Mar 3, 2017 12:22 PM
4.9Inline6e4OD
Jun 18, 2016 01:46 PM
Mikemusial
Sep 17, 2014 09:43 PM
RunRed
Aug 13, 2009 08:50 PM
Pud500
Aug 31, 2008 11:02 AM
