E4OD only has 1st and 2nd?
Old Aug 13, 2009 | 04:16 PM
RunRed's Avatar
RunRed
Working on a 96' and the auto will only shift into 1st and 2nd then it just holds it in second, will not shift to 3rd or 4th. Doesnt matter where the pedal is or if you hit the O/D off. Any ideas?
Old Aug 13, 2009 | 06:16 PM
Cuda_jim's Avatar
Cuda_jim
It could be the shift solenoids or the wire connections to it. The best way to know for sure it get it on a scanner that is capable of reading the trans.
Could be the trans is in 'limp-in-mode'. Does it shift hard too?
The trans will do this to protect itself from further damage by increasing the pressures.
Old Aug 13, 2009 | 08:50 PM
Passin Thru's Avatar
Passin Thru
My relay under the hood went out and made it go amuck once in W VA of all places.
F350Bandit
Nov 11, 2012 07:37 AM
laciclemens
1997 - 2003 F150
Apr 5, 2011 02:47 PM
mattri
Aug 2, 2010 09:20 PM
lv2race
Aerostar
16
Oct 26, 2005 10:36 PM
gnmano
1978 - 1996 Big Bronco
Feb 22, 2004 07:40 PM
