Question for the 4R100 Experts?
Old Jan 3, 2009 | 03:47 PM
tnnuke's Avatar
tnnuke
I just bought an 02 F250, 4x4, 7.3L truck. The truck has 97K miles and the transmission fluid has never been touched. I am one of those guys that change his fluid every 30K miles, but I have been warned on this truck. I was told by a Ford dealer and several other folks that if this truck had never been serviced with 97K miles do not touch the fluid because once you flush it and change it, the tranny will fail soon after becaue of the deposits that will break loose?
Has anyone else been told this? I was hoping to put a shift kit in it but now I guess I will run i until failure and not mess with it.
Any input would be appreciated.
Rob
Old Jan 3, 2009 | 08:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I've been told this, too. It's not true. There is NEVER a time where old trans fluid is better than new fluid.
Old Jan 3, 2009 | 08:43 PM
tnnuke's Avatar
tnnuke
Fluid is pretty dirty. So there is probably some deposits in the unit.
It makes sense. The fluid is mostly detergent and when you change it, the fresh detergent will clean everything well and break the deposits loose that ruins the tranny.
Rob
Old Jan 11, 2009 | 04:39 PM
Mark Kovalsky
You're welcome to believe that old wive's tale if you like. It isn't true.
jackfrost9p
Sep 2, 2014 11:05 PM
brobrad
1997 - 2003 F150
Nov 8, 2013 11:35 PM
someday
Mar 3, 2012 10:31 PM
gdfrick122
May 30, 2008 11:33 PM
LARIAT 85
Oct 3, 2007 01:27 PM
