E4od/4r100
Old Sep 15, 2014 | 11:25 AM
Mikemusial's Avatar
Mikemusial
E4od/4r100
I have a e4od. And my buddy told me the valve body might be bad causing violently hard shifting in all gears. Unless I'm towing.... Then it shifts fine. Anyways, I was wondering if anyone knows if the 4r100 shift solenoid pack/valve body is interchangeable with the e4od. He has a good 4r100 valve body and if it works it's going in later today
Old Sep 16, 2014 | 12:16 AM
JSchuricht's Avatar
JSchuricht
It's not the same, the E4OD uses a on/off solenoid for TC lockup, the 4R100 is PWM.
Old Sep 17, 2014 | 09:43 PM
Leatherneck007's Avatar
Leatherneck007
check your VSS first before tearing into the tranny. change it and see if it shifts better. check the fluid level in the diff also. if its too low it will cause the sensor to not read as well.
Eicca
Aug 1, 2011 11:03 AM
madmoose
1978 - 1996 Big Bronco
Oct 24, 2003 09:33 PM
