Sponsored by: Real Truck
Diablo Predator vs Edge Evolution?
Old Jan 6, 2009 | 07:46 AM
riverrat41's Avatar
riverrat41
I have a 2002 F-350 4x4 7.3 powerstroke auto.215.000m.I have been running the Diablo Predator for 4 years.Just recently sent it back to Diablo to update the new tunes.I have more power now but lost some mileage.I was thinking about switching to the Evolution if it had comperable power because I wanted the monitor with gauges(EGT,Fuel pressure,boost).What do ya'll think?Is there a gauge set-up that I can use with the Diablo.I am not a racer but need the power for pulling and mileage....Thanks
Old Jan 6, 2009 | 08:17 AM
m350's Avatar
m350
I was just going to make a New post about the Edge Evolution programmer,,here is the info I found for my 06' six-0:
Ford New Evolution - 2005-2007 Ford 6.0L Powerstroke Evolution
SEE CHART BELOW FOR EXACT APPLICATION
Level 0: Stock
Level 1: 15 Horsepower - 55 Foot Pounds of Torque
Level 2: 60 Horsepower - 110 Foot Pounds of Torque
Level 3: 100 Horsepower - 200 Foot Pounds of Torque
FORD 6.0 POWERSTROKE 2005-2007
KEY FEATURES
• FIRST PROGRAMMER TO READ AND DISPLAY EGTs, probe included
• Provides in-cab display to monitor vital engine functions
• Additional 100 HP and 200 ft. lbs of torque
• Three power levels with special mileage tune for improved fuel economy
• Ships with a custom designed pod
• Internet updateable (cable included)
• Displays and clear diagnostic trouble codes
• Adjustable LED backlight color
• Does 0-60 and Quarter mile performance tests with the drag strip Christmas tree lighting and reaction times
• Displays Alerts and Records such as RPM, MPH and EGT
• Datalogs vital engine information
• Simple installation
ADVANCED TUNING
• Able to adjust shift points/pressure
• Adjustable speed/rev limiter
• Speedometer correction (corrects tire size on vehicles with ABS)
PERFORMANCE TESTING
• 0-60 and Quarter mile performance tests with the drag strip Christmas tree lighting and reaction times
DATA STREAM
• Records 5 parameters for up to 60 seconds
• Viewable graph using available software
PIDS
The Evolution allows the user to view up to 4 PIDs at one time. There are 11 different PIDs to choose from. Below is a list and description of each:
• RPM (revolutions per minute) – Engine speed.
• MPH (miles per hour) – Note: Dash display may be +/-3 MPH off from the digital display due to mechanical differences in the spring, etc. used to control the gauge.
• ECT (engine coolant temperature) – Degrees F.
• BST (Boost Pressure) - PSI
• EGT (Exhaust Gas Temp) – Degrees F.
• EOT (Engine oil temperature) – Degrees F.
• TFT (Transmission fluid temperature) – Degrees F.
• IAT (Intake air temperature) – Degrees F.
• BARO (Barometric pressure) – PSI
• BAT (Battery voltage)
• DTC (Diagnostic trouble code count)
The following power gains are representative of an actual test vehicle. These gains were measured on a SuperFlow Dyno at an altitude of 4400 ft above sea level, and represent power delivered to the rear wheels of the test truck. The only modification made to the test truck was the addition of the Edge Evolution module. Power gains may vary based on vehicle and geographical location.
Level 0: Stock
Edge Part Number
Discription
Engine
15003 - EEF1220
Edge Evolution Programmer
6.0 Powerstroke Diesel
This is from Ebay,,$ 479.00 free shipping,,,now I always heard the the Edge was tough on the tranny,,,but I see on here it says it is " able to adjust shift points/Pressures,,,,is'nt this the same the same thing that the SCT can do ?
That Edge Evolution Programmer with all the different things it can watch,,even has a EGT probe comes with it,,looks like a sweet setup,,,Just wanna know if anybody has it,,and any problems with your truck ??
Have they changed anything to help the tanny from a few yrs ago ?
Old Jan 6, 2009 | 09:07 AM
Pocket's Avatar
Pocket
The Evolution is going to work about the same as the Predator. Companies such as Edge, Hypertech, Diablosport, Banks, and Superchips make generic tunes for the 7.3L. They all work about the same.
Most 7.3L owners prefer a chip and standard pillar gauges. Most popular chips are from DP-Tuner, Total Diesel Performance, and Diesel Innovations. These chips usually offer better tuning and more options. For example, a DP-Tuner chip can hold up to 16 different programs, and they are all switch on the fly. No waiting for the programmer to download a tune onto the PCM, just press a button while you are driving down the road and you are in a different setting.
Another benefit of a chip is that each program is specifically written for your PCM code, not just a range of years like Edge, Banks, etc. This gives you better transmission tuning, as well as timing control, fuel delivery, and EGT control. Many of these chips can run higher horsepower settings with less EGT's. You can search down in the 1999-2003 7.3L forum further down and see how many folks really like these chips, as well as the customer service they get.
Here are the links you can check out:
DP-Tuner
http://www.totaldieselperformance.com
Diesel Innovations
Old Jan 6, 2009 | 02:52 PM
Fordfanatic4life's Avatar
Fordfanatic4life
dam adding 200lbs of torgue to the 6.0 would scare the crap outa me.. i'd be to afraid of blowing the heads off...
have u considered the SCT tuner ???
5 Star Tuning | Custom Dynomemeter Chassis Tuning Products and Services
they seem real popular here on the boards...
Old Jan 6, 2009 | 03:06 PM
DCSpecial's Avatar
DCSpecial
If you are looking for an Evolution II, check out Power Hungry Performance.
They offer the custom tuned Gryphon.
They also have the Phoenix (custom tuned 6 position).
Power Hungry Performance - Feed your hunger for POWER! Check out our Gryphon Programmer for Ford vehicles!
They are supporting vendors here.
Old Jan 6, 2009 | 03:34 PM
damuddog's Avatar
damuddog
What's the verdict on these programmers? They seem pretty cool. Not a bad price either when you take into consideration that gauges are not needed with this unit.
Old Jan 6, 2009 | 03:51 PM
Groovy Chick's Avatar
Groovy Chick
Former Vendor
Level 0: Stock
KEY FEATURES
ADVANCED TUNING
PERFORMANCE TESTING
DATA STREAM
PIDS
Level 0: Stock
Edge Part Number
Discription
Engine
15003 - EEF1220
Hi there,
If you're in the market for an Edge Programmer, I just wanted to make you aware that Power Hungry Performance sells a private labeled version -- the Gryphon -- that can be CUSTOM TUNED. We can replace one or all of the canned tunes with any of our standard calibrations. We can also tune for heavy mods, but those files require an additional custom tuning fee. Of course, the Gryphon also offers different gauges that you can monitor and a dash-mount pod, as well. The 7.3L and 6.0L Gryphons also include a thermocouple in the price.
We also sell TS 6-position chips under the name Phoenix Module. The benefit of a chip is that it can hold more calibrations and has the capability of switching-on-the-fly, so there are more calibrations available -- like WhisperMode™ and SmokeShow™. We've also recently lowered the price of the Phoenix!
They're both wonderful in their own unique respect. Feel free to ask questions if you feel I can help you in any way.
(Thanks, DCS!)
Old Jan 6, 2009 | 05:25 PM
tex25025's Avatar
tex25025
Since I have found out a little more about this particular item, I have been thinking is a little ad. smoke and mirrors.
The tuners with built in DTC readers such as this(including Banks, SCT, Bullydog etc) can only read generic DTCs, ones that are common accross the board no matter what manufactor it is. They, however, cannot read and clear manufactor specific codes, ones that are a little more nitty gritty codes, such as tranny codes or contribution/balance codes.
I really think that they need to re-word that, but it could just be me.
Old Jan 6, 2009 | 05:49 PM
Groovy Chick
Former Vendor
I can't speak for the other programmers, but I know that the DTCs for the Evolution and Gryphon come straight from Ford's DTC database.
Old Jan 6, 2009 | 06:04 PM
tex25025's Avatar
tex25025
Are you sure about that, because I know that they can't pick up the vgt code that my truck is throwing because I had one of the guys from the local shop for giggles hook up the "floor" unit after I found out that the SCT didn't read it(nor the cyclinder 7 code I had before that). I would make sure it still isn't a list of generic DTCs either that or we were messing with faulty ones.
JoshC017
Oct 15, 2016 07:12 PM
catzr440
Ford Truck Parts for Sale
Apr 15, 2016 05:18 AM
F250Nelius
Modular V10 (6.8l)
Apr 3, 2011 10:08 PM
Smokefan420
2004 - 2008 F150
27
Jun 4, 2007 01:01 PM
dirtroaddevil
Oct 27, 2003 07:10 PM
