re transmission HELP!
Old Jan 5, 2009 | 06:57 AM
riderbear's Avatar
riderbear
thanks for all the input...guess the zf6 is not a good idea.
here's the deal 87 f350 6.9 puked the trans (c6) on a road trip. looking for a replacement but NOT looking to spend 2k. Can anyone tell me... will a c6 for a 460 big block fit this application,as I found a rebuilt for a good price?
THANKS ALL
Old Jan 5, 2009 | 07:57 AM
fellro86's Avatar
fellro86
No a 460 bell pattern will not work, it has to be a diesel pattern. There are plenty of C6's out there, or ZF-5's if you want to stay with the manual swap. If you aren't concerned about the overdrive, there are the T-19's as well for manuals.
Old Jan 5, 2009 | 12:27 PM
David85's Avatar
David85
Diddo. 460 big block won't work.
I have a good C6 tranny for a 2wd diesel, but it would probably cost an arm and a leg to ship it to you.
Old Jan 5, 2009 | 01:10 PM
starmilt's Avatar
starmilt
the T18 gas tranny will also work ig you have the diesel bellhousing.
The last C6 I had rebuilt was around 400 bucks they are way cheaper than the aod trannys.
Old Jan 6, 2009 | 12:51 PM
84 f250 6.9's Avatar
84 f250 6.9
well said: people told me a t19 wouldnt bolt up to my diesel from a 460 which it will work cuz i have no problems w my t19 from the 460, gear ratios are same and the whole bit
Old Jan 6, 2009 | 12:58 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The T 18/T 19 is the only transmission that has a seperate bell housing though.
So it is the only transmission that will work on both a gas and a diesel with the correct bell housing.
ZF 5, ZF 6 and E4OD bell housings are part of the transmission, so they will not work.
Ken Blythen
15
Jun 11, 2011 05:03 AM
48Effie
Apr 11, 2007 04:11 PM
jseefcoot
Jun 16, 2005 02:41 PM
dsc
Mar 14, 2002 06:22 PM
TrackStar
Feb 11, 2002 08:45 AM
