HPOP lines
Old Jan 5, 2009 | 12:32 AM
TerminatorEng.'s Avatar
TerminatorEng.
Tim is right! Replace the O rings and be done.
Old Feb 15, 2009 | 03:29 PM
steelers06steelers's Avatar
steelers06steelers
How do you disconnect the line from the quick coupler fitting???
I tried pushing down on the line and pushing the release coller up/down but could not get the line off the fitting. Is there a trick???
Old Feb 15, 2009 | 04:03 PM
TerminatorEng.
OTC makes a nice tool to release them. Some people use two flat screw drivers on opposite sides of the fitting to release them as well.
Old Feb 15, 2009 | 04:29 PM
PaysonPSD's Avatar
PaysonPSD
This should help you figure it out.
Home made disconnect tool by Guzzle
Old Feb 15, 2009 | 05:55 PM
guzzle92's Avatar
guzzle92
Make sure you use the Loctite 608 retaining compound on the first three threads of the discharge fittings or it will leak on you again shorty down the road.
Also, I have found that if you can make a tool from something closer to 1/8" thickness, it works better. The one I made, you have to move it to one side or the other to get the snap ring to move enough to release the line. A thicker tool would not require anything more that just inserting it. You could make one from 1/8" flat stock bar metal and a grinder or file.
Old Mar 23, 2009 | 10:07 PM
ford montana's Avatar
ford montana
Just replaced one of the lines on buddies truck for five bucks ,got rid of the quick fit stuff got the right fittings at tractor store have braided line at work cost almost nothing
Old Mar 23, 2009 | 11:08 PM
TerminatorEng.
Make sure that line is rated for 300 degrees and at least 3500 psi working pressure, or you will have a messy surprise!
Old Mar 23, 2009 | 11:10 PM
bdrummonds's Avatar
bdrummonds
I was just thinking the same thing. Our Hpop is realitively low pressure in the hydraulic world, I would think you would be able to find the correct bosses and fittings to make some 5000 PSi line work
Print out above pics and take to Parker dealer and see what they would charge to make you new lines. (probably $50 each)
I know you could do it B/C the SSHPX from KCM uses bosses and JIC fittings.
Old Mar 23, 2009 | 11:15 PM
SpringerPop's Avatar
SpringerPop
Care to share with us what "the right fittings" are?
Pop
Old Mar 23, 2009 | 11:46 PM
bdrummonds's Avatar
bdrummonds
Pop
Hey Joey, what size are the bosses that go in the HPOP and rails?
1/8th NPT to JIC? SAE? AN?
Steelheader87
Apr 19, 2017 06:50 PM
fridgeddiesel
Mar 27, 2017 12:06 AM
derek0525
Oct 12, 2016 03:03 PM
hydell3
Sep 23, 2016 11:50 AM
portsample
May 21, 2016 07:02 PM
