Sponsored by: Real Truck
2006 f250 headlight switch
Old Jan 3, 2009 | 03:23 AM
Fordflanigan's Avatar
Fordflanigan
hey guys i just installed some recon clearance lights to my truck and i need to wire them into my parking light wires.
How does the light switch cover on the 2005 and up models com off? I tried popping it off like my friends 04 comes off but it did not come off and i think i broke it
Is there tabs or bolts holding it on in the back?
Old Jan 3, 2009 | 07:14 AM
rwilimo's Avatar
rwilimo
The proper place to connect the roof marker lights is in the harness connector in the right side kick panel. It will be a brown wire.
Old Jan 3, 2009 | 08:34 AM
Grey 250s's Avatar
Grey 250s
flanigan
our 06's do have the clearance light harness connection behind the passenger side kick panel as rwilimo describes. I installed the clearance lights and never touched the headlight switch. There are a many informative and very detailed threads about this. Use "clearance lights" or "cab lights" as the key word in the search function. Detailed description is Motoman's Madness
Also, by far the most comprehensive photo album that I've seen was posted by bpounds a couple of weeks ago. Look here Cab Clearance Lights pictures from cars photos on webshots
good luck. Hope you didn't break your switch.
Old Jan 3, 2009 | 11:04 AM
GT4point6's Avatar
GT4point6
If your harness for your lights isn't Ford and you have to tap into the wires, pull the bezel off the intrument cluster. It will take a little effort but will come off. Then get to the light switch from behind.
Old Jan 3, 2009 | 11:08 AM
rwilimo's Avatar
rwilimo
Even if your not using a Ford harness I would still connect to wiring in the right kick panel, as that is why it is there.
Old Jan 3, 2009 | 08:26 PM
da X-man's Avatar
da X-man
Does this apply to the 2000 super dutys?
Old Jan 3, 2009 | 08:28 PM
rwilimo's Avatar
rwilimo
I believe it does.
Old Jan 4, 2009 | 02:09 AM
Fordflanigan
thanks for the help guys! i origianally planned to put it in the passenger kick panel but when i peeked behind my kick panel i coud not locate the plug. but i probly need to pull the panel off to see it.
thanks again guys!
nightowl263
Jan 2, 2015 09:41 PM
Jasonf150
Nov 8, 2014 11:51 PM
rews2
Aug 4, 2014 12:43 PM
abe
Jul 30, 2014 07:56 PM
BigBlockF350
28
May 4, 2013 10:33 AM
