front end swap
Old Jan 2, 2009 | 09:38 PM
spshauling's Avatar
spshauling
front end swap
hi
I have seen the front end swaps from the 86 to the like 91 or so
got get the newer composit headlights and the newer looking front ends
I ahve heard several stories
I ahve the 86 hauler and can get a 91 or 92 that has a great front end and doors, does anyone have aidiea what all needs to be replaced
I would like to use the doors fenders hood bumper grille
everything from the doors up if posible
can all this just bolt on
thank you again for your help
Old Jan 2, 2009 | 11:26 PM
Fordzilla80's Avatar
Fordzilla80
Originally Posted by spshauling
hi
First off,91 and 92 are two different front end styles,in case you didn't know.
The doors on your truck currently will work with the new front end.If your doors are rusty,then any door from 1980-1983 F100,1980-1996 F150 and F250 will work.You will have to get the hood,fenders,grille,headlight bezels,bumper,and I believe the radiator reinforcement panel also from the newer truck.As far as I know,most of it bolts up.You may have to drill a couple holes,but nothing majorly extensive.Alot of people have done this before.There will be more guys on here in the mornin with experience in front clip swaps that will be able to help you a thousand times better.Good luck!
Old Jan 2, 2009 | 11:43 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Sycostang67 has an '85 chassis with an updated clip.
If I recall, it all fits right on once you've changed the radiator support.
With a few more posts you'll be able to PM him.
Perhaps you could search through some of his 116 pages of posts?
Old Jan 3, 2009 | 12:57 AM
Franklin2's Avatar
Franklin2
The easiest way is to unbolt the whole front clip as one piece and install it. I have never done it myself, but remember guys who have, say the lower fender bolt down low on each side is a little different but can be modified to work, and the front frame horns are a little bit different, so the later model front bumper needs a little modification to bolt on.
I can't remember if they said the wiring will plug in or not. Of course your headlight plugs will be different, but if the wiring will plug into the main plug, that may not be a problem.
Old Jan 3, 2009 | 02:08 AM
Sycostang67's Avatar
Sycostang67
The lower fender bolt problem can be fixed by bending the tab or using "L" brackets. I just cut the headlight plugs off the new truck and spliced them into my truck. The wires were all the same colors so it was easy. Everything previously stated is also correct.
cadunkle
Feb 11, 2019 09:03 PM
seattleF250
Dec 10, 2009 05:00 PM
dantsg
Offroad & 4x4
Sep 13, 2009 11:15 PM
STX04
2004 - 2008 F150
Jul 28, 2008 09:54 AM
chad85
Feb 24, 2008 03:32 AM
