Shimming the FPR means installing a BB. I'll see if I can find the link for you or you can try a search for "FPR Shim". There should be some pictures along with the instructions.
You'll need a Q-tip with the cotton removed to clean the FPR screen.
I don't how to check to the stuff Joe mentioned. I'm waiting for him to respond to you.
Here's a link to check out. It isn't the one I was thinking of, but I'm still looking.
we put three different gauges on it and never got over 25 to 30 psi. why does the gague needle bounce real bad? when i reved it up to 3300 rpm maby got 35 psi. what is the next step?
If you have low fuel pressure, I wouldn't do the shim mod to fix it. Likely you have a weak pump, I'd fix that properly first. Also if you can get data stream check your HPOP pressure maybe.
