CARNAGE! need help.
Old Jan 2, 2009 | 06:18 PM
  #31
powerstroked162's Avatar
powerstroked162
I had this exact same thing happen on ym 350 dually and it was everything you just explained. My cause was a broken brake assembly in the hub which locked the drum up in the rear and the torque was so much it sheared the bolt heads off and spit the axle out of the housing. Axle looked brand new, not a scratch on it to when it got spit out. The splines lined back up perfect. I never heard a squeak, nor a grind, nor loss of pedal, i mean nothing before then to lead me to believe it had bad brakes. When I pulled the drum off the shoes were worn to the metal so much the rivets were gone. The one shoe got mangled into the drum which locked it up and all the retainer clips, tensioin springs, and e-brake assembly were destroyed. It left a pile of chewed metal in the drum. I would since you got it apart for the most part, pull the drum and check it out. Even if you think its not that still dosn't hurt to check your brakes anyway since its apart. I would check bothsides as well. I did on my dually and found the otherside to be ok and i really didn't have to but the peace of mind was worth the time. I would also if you dont tear the otherside down, re-torque those bolts as well. Best of luck
Cowboy Steve
*EDIT*- Guess im a few posts to late, lol. Glad to hear you got it fixed. I still wouldn't hesitate to take a look at the brakes and drum assemblies. You dont spit axles out for no reason, If it was my truck Id want to know especially if it was my daily driver.
Old Jan 2, 2009 | 06:54 PM
  #32
klr's Avatar
klr
pardon me to chime in on your thread but I have to watch my bolts on the left rear only. they work loose all the time. so much so that I left the center caps off just to keep an eye on them
Old Jan 2, 2009 | 07:08 PM
  #33
powerstroked162
Loc-tite should be on al your running gear hardware
Cowboy Steve
Old Jan 2, 2009 | 07:09 PM
  #34
c00nhunterjoe's Avatar
c00nhunterjoe
blue bottle, red liquid
Old Jan 2, 2009 | 07:12 PM
  #35
powerstroked162
"The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again. ITS A VICIOUS CIRCLE THAT BRINGS ME JOY"
Fixed your sig fer ya Joe
Cowboy Steve
Old Jan 4, 2009 | 08:57 AM
  #36
klr's Avatar
klr
I think I'am going to give loc=tite a try thanks
KsCop
Nov 19, 2013 05:23 PM
DAVE67FD
May 30, 2009 11:51 AM
MustangGT221
15
Aug 1, 2007 08:01 AM
akatrd
Mar 19, 2007 03:00 PM
teg2_nv
Dec 21, 2006 01:13 PM
