Sponsored by: Real Truck
Rear Axle Alignment
Old Dec 19, 2006 | 08:46 PM
teg2_nv's Avatar
teg2_nv
Rear Axle Alignment
I changed my rear leaf about a year ago and one day I noticed that the axle didn't seem to be in the center of the body. I took the tires off today and loosened the u-bolts and when loose became centered. When I tightened everything back up it and put weight back on it it seemed to be back to the exact same spot. About 2" off center.
Has anyone had this problem? Should I drop the truck, putting weight on it before tightening up the u-bolts?
Old Dec 19, 2006 | 08:50 PM
PHWLEE's Avatar
PHWLEE
Never noticed that before. I'll go take a look in the AM with some daylight. Maybe someone else might have a thought on this in the meanwhile.
Old Dec 19, 2006 | 09:04 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
get a straightedge of some sort and measure off the tire edges to the frame and the body on both sides to make sure what your seeing is true
Old Dec 19, 2006 | 09:05 PM
Sport45's Avatar
Sport45
Centeref front to back or side to side? There should be a centering pin where the leaves and the axle housing come together and not a lot of room for adjustment either way. Surely not 2 inches worth.
Old Dec 19, 2006 | 10:54 PM
teg2_nv's Avatar
teg2_nv
The centering pins are aligned.
Does anyone know if an alignment shop can check the rear axle.
I have also had some poor tire wear in the front and the truck seems to almost skate on the highway. Would shocks or spings cause this?
Ball-joints and tie rods are all good. Alignment is within spec - about a degree off in camber and 1/16" toe-in (the guy only did the front).
Old Dec 19, 2006 | 11:08 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, ask for a 4 wheel alignment. Some may tell you no, but that usually means they just don't want to do it.
Old Dec 20, 2006 | 07:04 AM
350z's Avatar
350z
Is it posible that its not the right spring , or that the spring eyes are the same and its in backwards putting the centering pin offset in the wrong direction ?
Old Dec 20, 2006 | 08:34 AM
teg2_nv's Avatar
teg2_nv
The springs are OEM confirmed through the VIN, they visually match the old springs.
If the springs were installed backward wouldn't it be quite difficult to align the axle? I remember when putting them on they were a little fussy to get them to sit in the pin, but nothing to serious.
Old Dec 20, 2006 | 09:46 AM
redford's Avatar
redford
Something is seriously wrong of your axle is 2 inches off center.
IMO - If the springs were backwards, that would move the pins forward or backwards, but the side-to-side track shouldn't move. If you didn't get the perches seated on the pins, or if the pins were somehow broke I could see this happening.
Old Dec 20, 2006 | 10:10 AM
redford's Avatar
redford
Has that truck ever been hit?
Old Dec 20, 2006 | 01:16 PM
a-rod's Avatar
a-rod
Sounds like your frame might be bent, Was it wrecked at one time? Have a good body shop check your frame for a (diamond). That would explain bad tire wear as well.
Old Dec 20, 2006 | 01:21 PM
a-rod's Avatar
a-rod
also look at the gaps between the bedsides and the cab, should be even on both sides, if one side is alot wider or tighter, thats a good sign of a (frame diamond)
Old Dec 21, 2006 | 12:27 PM
teg2_nv's Avatar
teg2_nv
1/2" off-center
I rechecked the offset and it is about 1/2" off center now, after I loosened the u-bolts to check to see if all alignment pins were in place. Would a 1/2" be acceptable? Could an alignment shop correct this or should I still have a body shop take a look at it?
As far as I know it has never been in an accident, but then again I bought it used.
Old Dec 21, 2006 | 01:13 PM
a-rod's Avatar
a-rod
I would have a body shop check it out, shouldnt be off that much
jbontke
Aug 8, 2015 09:06 PM
kbsupercrew
1997 - 2003 F150
Mar 13, 2012 08:08 PM
Tomahawk
6.7L Power Stroke Diesel
45
Oct 21, 2011 11:07 AM
Stewart_H
Nov 3, 2008 07:47 PM
LCA078
Nov 1, 2007 05:15 PM
