removing pilot bearing
Old Dec 31, 2008 | 08:24 PM
hotroddually's Avatar
hotroddually
my son called me last night. he is doing the clutch in his '94 f 150 4x4. its a 5 speed trans. he was trying to remove the pilot bearing and couldn't get it out. i told him to fill the center hole up with grease and find a snug fitting dowel, or bolt and hit it with a hammer so the grease would push the bearing out. he tried and that didn't work.i have never found it hard to remove this before.im not close enough to go help him,so if anyone has an alternative method to remove the pilot bearing i would be greatful for the suggestions. im conserned he may damage the fly wheel if he tries pounding it out. thanks
Old Dec 31, 2008 | 08:25 PM
ctubutis's Avatar
ctubutis
Go rent a pilot bearing puller.
Old Dec 31, 2008 | 09:01 PM
75F350's Avatar
75F350
Fill the bearing and crank with grease, and find or make a dowel that fits inside of the pilot bearing. (inside diameter) Then whack the dowel with a hammer. It does not take much, and it will pop right out. Be sure that you put a rag over everything as grease will fly around a little. Clean out crank, and install new bearing.
Simple and quick.
I know that you mentioned that, and it was not working, but I have yet to find a bearing that I cant remove this way. Make sure that the dowel is snug, or the grease will escape.
Old Dec 31, 2008 | 10:36 PM
rebocardo's Avatar
rebocardo
I have had pilot bearings (cage type) that went bad, ran dried, seized and welded to the crankshaft, and I had to remove them the hard way, especially since the factory ones may not have the notch that makes having a puller worth while.
The hard way involves removing the flywheel, getting an air chisel, and splitting the bearing/bushing in 1/2 or 1/4s without mauling the crank snout. I ground my muffler cutter to a fine edge and down so it would cleanly split the bearing. Then I used a needle nose to pick out the pieces. You have to clean it really well afterwards.
Old Dec 31, 2008 | 10:56 PM
mark a.'s Avatar
mark a.
You can buy a puller dirt cheep.
Old Jan 1, 2009 | 09:31 PM
hotroddually
thanks for all of the replies folks. my son got it out today. the old grease and dowel trick wasn't working yesterday but it did partially today. so he got out the dremel and cut a groove in the outer race and then wacked the side of it with a punch.it split in half.he then worked it out. tommorrow i am going out to his house to put it all back in. new pilot bearing ,surfaced flywheel,new clutch,pressure plate and new hydraulic slave cylinder.
Michaelocalypse
Nov 27, 2016 01:05 PM
Brant Bowrifle
Jan 3, 2013 02:55 AM
jiveturkey692000
Mar 5, 2011 09:53 PM
jlynn8403
Sep 8, 2009 04:16 PM
78 Ranger
Feb 17, 2006 02:36 PM
