Rear wiper stopped working
Old Dec 28, 2008 | 08:47 PM
froggy47's Avatar
froggy47
Actually this is the 3rd time it has stopped working. 2000 exp xlt with 75000 mi.
Twice repaired by the dealer under warranty & ext warranty. Not sure how he fixed it.
I assume this is a fairly common failure as mine quit 3 times so far.
Any suggestions on how to go about trouble shooting it? I'll be fixing it myself.
Thanks.
Old Dec 29, 2008 | 02:24 AM
srercrcr's Avatar
srercrcr
Mine quit years ago. There's been posts over the years. I figure it just doesn't want to be there.
Old Dec 29, 2008 | 02:08 PM
froggy47's Avatar
froggy47
My daughter drives the explorer now so I want it working for safety mainly. I tried search & did not find anything useful.
If anyone can direct me to a useful thread I'd sure appreciate it.
Thanks.
Old Dec 30, 2008 | 07:10 AM
ccecilm2's Avatar
ccecilm2
This thread may help ...
https://www.ford-trucks.com/forums/6...wiper-fix.html
Old Dec 30, 2008 | 07:45 AM
ripcurl94's Avatar
ripcurl94
yeah mine didn't work when i bought my 98 in 03.. i said.. hum.. good thing i will never need it anyways... so far i was right.
Old Dec 30, 2008 | 10:19 AM
AuRevoir's Avatar
AuRevoir
My 99 Limited has the same intermixing problem. Is the panel on the door easy to remove to access the switch/motor?
Old Dec 30, 2008 | 02:45 PM
froggy47's Avatar
froggy47
Thanks all, found a few threads, looks like it's probably the window open sw.
I'll take her apart next time the truck is here.
I bet if I clean it & put some dielectric on it'll be good to go.
Old Dec 30, 2008 | 10:17 PM
nitrogen's Avatar
nitrogen
had a 91 with rear wiper issues, it turned out that the power wire was corroded off the connector behind the front passenger kick panel, seems like a hotspot for corrosion
Old Jan 3, 2009 | 08:15 AM
87bronco58's Avatar
87bronco58
Smile
Hey froggy before you get your DVOM out the ground that the motor uses is actually on the mounting base if you wiggle the rear wiper arm I bet it would work for a little bit the fix is relatively simple take the motor loose clean the mounting of all corrosion and reinstall. Hope this helps!!!
99FORD EXPY.
6.7L Power Stroke Diesel
16
Dec 8, 2013 07:39 AM
bunique09
Jun 13, 2013 07:18 AM
Ammie
Jun 22, 2010 10:20 PM
marv02
Feb 26, 2006 08:20 AM
78 Ranger
Electrical Systems/Wiring
Nov 13, 2005 08:02 AM
