Exhaust manifold leak.... Possible solution?
I removed the exhaust manifolds and now I have a slight exhaust leak. I pretty sure I pinpointed the problem to the first cylinder where the manifold meets the cylinder head. I'm guessing this is because the exhaust manifold is slightly warped due to age.
Possible solution.... I'm thinking about getting an exhaust manifold gasket and cutting it out to just use the first cylinder to make up for the warped manifold. Do you think this is a good idea or will I just devolope leaks on the other cylinders?
I checked the bolts and they were tight.
As far as putting 2 gaskets on you would be wasting your time as you would create a gap. I know it would suck to completely remove the manifold. Trust me I have to do this on my buddys 96' f-250 with a 460. I had a stud snap off. I do recommend just biting the bullet and doing it right the first time.
REMFLEX Exhaust Gaskets: Home Page
I've got an exhaust leak on my '97 (yeah, I think I'm in the right forum, it's the pre-Superduty '87-'96 style) F-250HD w/ 351, Cali emissions. Lacking easy access to a smoke machine, I built up an airhose adapter out of PVC plumbing fittings and put a few psi into the tailpipe. This allows you to feel/listen for the leak location. As near as I can tell, it's leaking out the right-side exhaust manifold, front cylinder. However, there's also an EGR pipe that connects right in this same area. Still not sure if it's manifold or EGR. Anyway...
Does this engine use exhaust manifold gasket from the factory? I am thinking no. I have AllDataDIY which lists the contents of the OEM head gasket kit... no mention of exhaust manifold gasket. Then I checked NAPAonline and they sell replacement manifolds (for $109, surely Chinese) "complete with everything needed for installation" which amounts to two studs. Neither of these is what I'd call definitive proof, but it sure SOUNDS like there's no gasket.
So what's up? Anybody Been There Done That? Cracked or warped manifold? Or is that EGR a common, known issue?
I was just about to dig in and start snapping studs, but of course they're predicting 5-9" of snow tonight and I think I might want to drive my truck for the next couple days, blatty exhaust and all, rather than the summer-tired Focus 2.3.
robotunderpants
10-04-2016 08:26 PM
IDAH0.REDNECK
03-03-2011 05:12 PM
vlietracer64
04-01-2010 11:21 AM
