Warped Exhaust Manifolds?
1995 F150 351W Ext 4x4 E4OD
While I was out of town last weekend I let my dad borrow my truck and he took it upon himself to take the truck into the ford dealer due to an engine ticking noise. First of all I do not feel fully confident in the dealer and their honesty and if I would have had the choice I would not have taken it there. But anyways this is what their $95 diagnostic had to say (word for word):
"Tested drove, could not confirm a lack of power. TTraced noise to exhaust manifold gaskets leaking. Need to remove manifolds and check for warping and have manifolds resurfaced. Depending on how or if manifolds are warped, they may have to be replaced."
So it sounds to me like they basically drove the truck around the block, popped the hood and used a stethascope to locate the ticking sound. Which could have easily been done in less then 10 minutes at home. What a great way to spend $100. Sorry to go off on a rant just very dissapointed.
Is it possible/likely that the manifolds are warped? If so, how would they be able to tell by just looking at them? Because it sounded to me like they weren't certain of the cause of the ticking. If the manifolds are warped, will replacing the stock manifolds with headers solve the problem? That would be perfect because I was wanting to replace the entire exhaust system anyway.
Thanks I appreciate the help.
This is correct........If they had gaskets, someone has already had them off, or replaced with cheap red chinese copies, because of a cracked OEMs manifolds. Beware aftermarket exhaust manifolds from the ChiComms, they are crap.......I am dealing with the same issue on my Chevy class C motorhome 350.
KJNDIVER
37
08-19-2020 11:24 PM
z31freakify
Modular V8 (4.6L, 5.4L)
10-30-2016 01:35 PM
robotunderpants
10-04-2016 08:26 PM
ironmine
1999 to 2016 Super Duty
05-12-2012 05:50 PM
