I'm assuming they left it there but on other models they have the outlet so you can use it. I guess go to walmart an get the tape deck adapter is the best you'll get unless you swap radio's. on mine when I push that aux button it says no aux!
You need a P.I.E. adapter- it will let you play iPod or whatever through that Aux channel. Be sure to tell the shop exactly what year, and what deck you have- they are different even year to year from what I understand. The adapter hooks up on the back of your deck w/factory plug..
If your stereo has the AUX button then you can get a PIE adapter that will plug into the back of your stereo and convert it to an ipod plug, then when you want to listen to your ipod just press the AUX button.
