Ground Wire getting hot
Old Dec 27, 2008 | 09:34 AM
wideopen23's Avatar
wideopen23
What is the silver ground wire do comes from the back side of the motor to the firewall on the passenger side, I have been having some problems starting in the cold 30 deg and went out this morning to check the gpr after trying to turn it over for a minute with the motor barely turning over that ground wire started smokin like crazy and got extremly hot, the truck is an 02 7.3 any help
Old Dec 27, 2008 | 09:48 AM
joegebff's Avatar
joegebff
Gone Fishin for Mark
A wire getting hot almost certainly means a bad connection. Yuo need to clean all of your main gonnections, both positive and negative, at the batteries, to the motor & starter and to the body as well. You should also clean the alternator connections.
While you are at it you should check and charge both batteries.
Old Dec 27, 2008 | 10:00 AM
DieselCamper01's Avatar
DieselCamper01
^^X2 what Joe said.
Old Dec 27, 2008 | 10:18 AM
just another truck's Avatar
just another truck
It may not be that wire either that is the problem there should be another else where, but now the wire you have found is doing the work for 2, instead of just is own.. just a thought.
Old Dec 27, 2008 | 10:23 AM
megawatt00's Avatar
megawatt00
Can't add anything else here you guys hit ti right on the head!
Old Dec 27, 2008 | 11:09 AM
sneak's Avatar
sneak
Thats what struck me first.
Old Dec 27, 2008 | 12:08 PM
rbaker6336's Avatar
rbaker6336
Good advice,I lost my ground once and burned up my throttle cable that became the sole ground
Old Dec 27, 2008 | 12:15 PM
twags6's Avatar
twags6
Like the guys said, double check that all the connections are clean and that all the ground wires are there and connected.
Old Dec 27, 2008 | 06:44 PM
wideopen23's Avatar
wideopen23
thanks guys seems like it was a loose ground off the pass side battery,
thankyou for the brain storming,
Old Dec 27, 2008 | 08:07 PM
just another truck
Good to hear, thanks for getting back to us
bjarnold1
May 4, 2017 02:53 PM
riverrat41
6.7L Power Stroke Diesel
Feb 3, 2017 04:13 PM
Neckster55
Jul 29, 2016 07:33 PM
fyredude
Jul 15, 2016 01:56 AM
Roy34
17
Jun 8, 2016 10:12 PM
