1956 F-100 Battery Reversed
I recently bought a '56 F-100 that had been parked for many years. I hooked the battery up backwards by accident. The ground wire bolted to the frame went to the hot side and the hot wire went to the ground post on the battery. After nothing happened when I turned the key on I hooked it up right and it started. Did I cause any damage by doing this?
Lights don't care about polarity (in this case), so you're safe there. The only concern would be to the coil and points (but not really), and the instruments (but not really, because they are a resistive load, and the ammeter would just read backwards). The only real concern would be if you changed the battery voltage.
MyName1sMud
39
05-11-2012 09:41 PM
