After the jump start...Electrical issues
Old Dec 27, 2008 | 10:21 AM
jchamb11's Avatar
jchamb11
After the jump start, I have lost my F60-65 Code-Alarm system. No door locks,dash indicator LED and no remote start. Checked the in-line fuse at the battery post , and the 102 position breaker (swapping it with 101 the aux brake module)and they seem/are to be fine. Is there a third place for me to look next?
This has me stumped, I am confidant you guys can help as you have in the past for me! Thanks in advance!
7.3 4x4 auto,Crew drw. 118k miles
Old Dec 27, 2008 | 10:34 AM
just another truck's Avatar
just another truck
Can you pierce the power wire at the alarm box, check to see if you have voltage there..
Old Dec 27, 2008 | 03:35 PM
twags6's Avatar
twags6
Try doing what Pat suggested. There might be a fuse in the alarm itself. I remember reading somewhere that if you're getting a jump, you should turn your heater on high so that the extra juice has somewhere to go when you let off the starter.
Old Dec 27, 2008 | 03:57 PM
strickracing's Avatar
strickracing
turn the heater on and the lights on is what dodge training passed on to me when i was going to school it absorbs any voltage changes and keeps spikes from shorting electronics
Old Dec 27, 2008 | 04:19 PM
jchamb11's Avatar
jchamb11
Pat,Strickracing and Twags6, Thanks. I tested for voltage both sides of the fuse at the battery. We are good to go there. I am un-sure of which red lead coming thru the fire wall was the right lead, but of the two I didn't get power. Unless someone has first hand knowledge of the Code-Alarm and if it carries a re-set or a trip-able breaker I think I'll take her in to the shop Monday.
Thanks again Guys, Pat I am right down the road from you at 15 and Jefferson
Old Dec 27, 2008 | 08:12 PM
just another truck
You working Tuesday? We can get together and look at it. I would say Monday, but have a funeral to go to.. Even tomorrow if you want to spend a little time on her?
Datsyukfan
2004 - 2008 F150
Oct 20, 2022 09:38 AM
RKuhlman
Mar 25, 2013 08:40 PM
Loftatsea
Dec 19, 2012 06:03 PM
ManfredVonRichtofen
1978 - 1996 Big Bronco
Nov 27, 2011 07:39 PM
Liknit
1997 - 2003 F150
Feb 20, 2011 06:51 PM
