Sponsored by: Auxito
starter motor wire
Old Dec 25, 2008 | 07:51 PM
forder1000's Avatar
forder1000
starter motor wire
I just had the wire from the battery break at the starter due to corrosion, is there anyway to splice the wire or will I have to replace the entire wire harness, any ideas will be appreciated. Thanks
Old Dec 26, 2008 | 05:58 AM
chaser1602's Avatar
chaser1602
If it broke because of corrosion then it will be up in the wire also.Better to replace it.
You could put a new end on it also.Why waste your time doing that.Do it right the first time and be done
Old Dec 26, 2008 | 11:10 AM
forder1000's Avatar
forder1000
thanks for your thought, got under the truck today, there was enough good wire to put a new end on the wire
oneborn2fly
Nov 17, 2014 06:58 AM
leforrest
1997 - 2003 F150
Jan 24, 2013 07:34 PM
david00f150
Jun 6, 2006 04:16 PM
calaski8123
Apr 22, 2003 08:27 PM
RJLB
Electrical Systems/Wiring
Apr 14, 2002 02:25 PM
