Starter Question
Old Jun 6, 2006 | 02:13 PM
david00f150's Avatar
david00f150
Starter Question
I'm sure this sounds like a dumb question but I just put my new motor in my 87 F-150. For the wiring for the starter, there should be one wire directly from the battery to the starter, and one wire from the solenoid to the starter correct? If that is correct which post does the wire from the battery go to?
Old Jun 6, 2006 | 02:54 PM
Kemicalburns's Avatar
Kemicalburns
there is one cable going from the solenoid to the starter that is it.
Old Jun 6, 2006 | 03:40 PM
bobcf's Avatar
bobcf
after 92 the starters have changed. One big cable frome the battery, one small cabel frome the solenoid.
Old Jun 6, 2006 | 04:16 PM
mississauga's Avatar
mississauga
From memory the one cable goes from the positive side of the battery to one side of the solenoid and from the other side of the solenoid the cable goes to the bolt on the starter. Small wire about 16 or 18 gauge from ignition switch goes to the push on connector in the middle of the solenoid.On my truck the positive post is on the fender side and it is connected to the post on the solenoid that is closer to the front of the truck.I dont think it matters though as the solenoid is really a large switch.If you are using the old cables the way there are shaped may give you a clue as to how they were originally connected. I hope I have explained it clear enough .
98F150on33s
1997 - 2003 F150
Nov 26, 2014 11:28 AM
andydunks
Nov 23, 2014 04:34 PM
marsh rat
Oct 19, 2014 09:29 PM
LARIAT 85
Jul 8, 2009 07:52 PM
earlsfork
Feb 6, 2004 10:27 PM
