98 blower only works on High
Old Dec 24, 2008 | 08:39 AM
gravydude's Avatar
gravydude
Hello all,
I have a 1998 Mountaineer. The heater blower motor only works on high. No Low or Medium. Is there a variable resistor somewhere? Since the blower motor only has two wires, I'm thinking there should be something that changes it from 5v to 8v to 12v? (or whatever voltages?)
If this is the case, where should I look for this module?
Thanks in advanced and Happy Holidays!
Old Dec 24, 2008 | 11:45 AM
steve(ill)'s Avatar
steve(ill)
yes there is a resistor block. they are normally connected to the hot air duct , under the glove box. lay on the floor and look up. normlly a 2 inch suqare plastic block with 3-4 wires on it, and a screw holding it to the hot air plenum. air keeps it cool.
Old Dec 24, 2008 | 11:46 AM
steve(ill)'s Avatar
steve(ill)
somem were under the hood in the duct by the blower motor. im not sure on the 98.
Old Dec 24, 2008 | 11:49 AM
87 XLT's Avatar
87 XLT
Should be under the hood/passenger side & plugged into the plastic air duct with a 4 wire connector.
Old Dec 24, 2008 | 11:55 AM
87 XLT's Avatar
87 XLT
Yeah, a 98 "should" be under the hood. Same as my 97.
Old Dec 26, 2008 | 01:42 AM
Old93junk's Avatar
Old93junk
Are you needing one for the standard 4 speed blower, or the one for the EATC unit( electronic auto temp control)?, EATC resistors are HARD to come by. $183.00 ford only part...........If they have one, I had to go to 6 wrecking yards to find 1.
Old Dec 30, 2008 | 11:40 AM
aquanaut20's Avatar
aquanaut20
Yank it out and replace the thermal link, is either got hot or died of old age, looks like a diode. They are used in hairdriers, ect.
Check the blower housing for debris.
mribbich
May 19, 2016 01:22 PM
RIKIL
Jan 6, 2016 05:11 PM
becida
Jul 26, 2015 08:06 PM
brandonellisce
2009 - 2014 F150
Jun 19, 2015 05:58 PM
Quad Racer
Jul 31, 2011 01:21 PM
