Please help - 4wd not working.
Old Dec 29, 2008 | 12:18 AM
modeltford's Avatar
modeltford
Was trying to drive wife's 91 Explorer up driveway in the snow tonite, and made several clunking noises then no front drive. It has made this noise while in 4 hi or low several times over the last week - have needed it to get around in the 2 ft of snow we got. It feels like it's coming from the front end, but not positive. I've been very easy on it - has a lot of miles and can't afford to replace it right now. Seems to be fine in 2 wheel drive, so we can use it, but is a problem now.
I need ideas on what I can check. Spindles and bearings were recently replaced by the local dealer - so that's all good. Was wondering if might be auto lock hub possibly, or any suggestions?!
Thanks for your help!
Rich
Old Dec 29, 2008 | 04:21 PM
aquanaut20's Avatar
aquanaut20
These autohubs will not work if packed with grease (especialy when cold), they need to be flushed and lubricated with a light coat of light grease and a tablespoon of ATF..
Old Dec 29, 2008 | 05:46 PM
modeltford's Avatar
modeltford
Cool - I'll give that a try! Would the hubs trying to engage - or partially engaging - cause the clunking sound/feel?
Thanks for the help!
Old Dec 30, 2008 | 11:12 AM
aquanaut20's Avatar
aquanaut20
Yes, that is the cam trying to engage against the packed grease. Cannot compress solids.
Old Dec 30, 2008 | 05:02 PM
modeltford's Avatar
modeltford
Make sense! Thanks for the help, Aquanaut!
Last edited by modeltford; Dec 30, 2008 at 05:02 PM. Reason: keyboard can't spell!
