Blower motor?
Old Jul 27, 2011 | 08:01 PM
Quad Racer's Avatar
Quad Racer
Blower motor?
I have an 01 e250 extended work van with a 5.4 v8. Yesterday i turned on the AC and the blower only works on high. It's the same for the vent also. Is my poroblem the switch or the blower motor? Thanks in advance.
Old Jul 28, 2011 | 05:50 AM
JWA's Avatar
JWA
There should be a resistor bridge in the heater core case, near the blower motor that probably has an open circuit thereby eliminating the intermediate speeds. I think the blower motor is running just off its relay, direct to battery so to speak.
These are easy enough to remove and inspect, about $20 or so from NAPA etc etc.
HTH
Old Jul 28, 2011 | 05:50 PM
Quad Racer's Avatar
Quad Racer
Thanks, I will look into that. Sounds easy enough.
Old Jul 29, 2011 | 09:51 AM
WVVan's Avatar
WVVan
You might find this of interest:
HOWTO install new blower motor
Old Jul 29, 2011 | 10:50 AM
PStruwing's Avatar
PStruwing
Excellent post and write-up WVVan! I just did the blower removal myself to remove the leafs and dirt from inside the housing to increase the A/C efficiency.
Old Jul 30, 2011 | 08:45 PM
jamnjm's Avatar
jamnjm
While you in there, vacuum out any needles or leafs as mine caught on fire a few years back.....due to that open hot wire resistor.
Old Jul 31, 2011 | 08:41 AM
PStruwing's Avatar
PStruwing
Jamn great tip! I was amazed at what I found in mine, but then I live in a heavily treed area and the AC worked better too!
Old Jul 31, 2011 | 01:21 PM
jamnjm's Avatar
jamnjm
Your welcome! After mine caught on fire, I added window screen netting under the front windshield plastic vents to stop my pine tree needles filling it up....
watts1
Aug 12, 2014 04:07 PM
Tormz
Dec 4, 2013 09:48 PM
captain2207
Aug 25, 2013 02:50 PM
fixit5561
Jul 27, 2010 01:59 PM
chazb86
May 27, 2005 11:59 PM
